1996 2.5 TL Water Pump
I was going to replace the timing belt on my 1996 acura tl 2.5, and I figured I should buy a kit and replace the water pump and tensioner too. What kit should I buy that is quality, but costs under $160ish
Only use a OEM part for the water pump. Even the good brand kits are known to have issues with them leaking or seizing.
Water Pump: $129 19200-P1R-003 https://www.acuraoemparts.com/oem-pa...dXRvbWF0aWM%3D Water Pump Seal: $3 19222-PV0-300 https://www.acuraoemparts.com/oem-pa...dXRvbWF0aWM%3D Timing Belt: $45 14400-PV0-004 https://www.acuraoemparts.com/oem-pa...QtYXV0b21hdGlj Belt Tensioner/ Adjuster: $68 14510-PV0-003 https://www.acuraoemparts.com/oem-pa...QtYXV0b21hdGlj Use "acurazine" as a discount code and get 5% off your total. |
