Wheel offsets
Old 07-01-2019, 01:10 AM
Royal50's Avatar
Wheel offsets
Ok guys, I have a 98 RL and I'm looking to put some 18's. I would like a deep lip but not too aggressive. I just don't know what offset to go with without the wheels sticking out. I want to be able to tuck them. It isn't lowered yet but that's because I haven't found springs. Suggestions on offset? Thanks.
Old 07-01-2019, 04:22 AM
Received 16,260 Likes on 11,971 Posts
use an online wheel offset calculator to help you visualize
https://www.1010tires.com/Tools/Wheel-Offset-Calculator
Royal50 (07-01-2019)
Old 07-01-2019, 07:47 AM
Royal50's Avatar
How do I know what the stock wheels are? The calculator wants the stock width and offset to compare.
Old 07-01-2019, 08:25 AM
I did not know the specs off hand, so i googled.
https://www.wheel-size.com/size/acura/rl/1998/
there are two wheel sizes, but lucky for you,both have an offset of 55
6.5Jx16 ET55
7Jx16 ET55
for more information; because I didnt know what ET stood for.
Offset is stamped on a wheel as an ET value, which refers to the German phrase Einpress Tiefe. ETindicates the distance between the mounting surface and the geometric centre of the wheel (the symmetry axle), usually expressed in millimetres. When the ETvalue decreases, the alloy wheels will protrude further out.
according to that definition, the high offset of 55 means that they wont stick out that much
Old 07-02-2019, 12:18 AM
Royal50's Avatar
6.5Jx16 ET55
7Jx16 ET55
Thank you.
Old 07-02-2019, 04:48 PM
Royal50's Avatar
Originally Posted by Royal50
Thank you.
Anyone has pics to share of their RL with wheels?
Old 07-02-2019, 05:49 PM
sadly, i think it's just us in this conversation.
Old 07-03-2019, 12:27 AM
Royal50's Avatar
That's too bad. I know there's got to be other users here with RL's lol.
Old 07-03-2019, 06:16 AM
^I found some on google!
Old 07-03-2019, 06:18 AM
https://www.stancenation.com/2013/01...able-acura-rl/
Old 07-03-2019, 09:38 AM
Royal50's Avatar
[QUOTE=justnspace;16447805]https://www.stancenation.com/2013/01...able-acura-rl/
thanks for sharing. A lot of those I seen on Google as well. I was just hoping someone would pop in here and show theirs so I would know the offset they used.
Old 07-03-2019, 10:27 AM
From experience, those are very low offsets.
in the website that I provided, the article states the fronts are 19×9.5 +8 ...and the rear is 19×10.5 +0
VERY LOW offsets. which he countered with camber, as to not to rub.
Old 07-03-2019, 10:31 AM
from experience, here is my car...with what I THINK is an aggressive offset +22
i am running a square set of; 18x9.5 +22
those gentlemen with the +8 and +0 are EFFING crazy to run that low
Old 07-03-2019, 02:01 PM
Royal50's Avatar
So in your opinion, will these work without sticking out of the fenders?
Old 07-03-2019, 02:29 PM
what is the width of the wheels?
18" is the diameter and +20 is the offset. missing the width.
+20 is pretty aggressive, depending on the width.
Old 07-04-2019, 07:26 PM
Royal50's Avatar
They are 19x9 front and 19x10 for rears.
Old 07-04-2019, 11:58 PM
You will have to do what those gentlemen did; play with height, play with camber, play with tire size, play with fender to get them to fit.
Your proposed set is more aggressive than my set and I had to roll and pull fenders, and raise my shit up, in order not to rub. But of course, I like race car tires! Wide and fat. You will have to play with all variables, especially tires. You will have to stretch tire or put a narrow ass tire on that wide ass wheel
You won't be able to tuck with springs, you will need coilovers or air
Old 07-05-2019, 03:59 PM
Royal50's Avatar
That's why I was thinking of going with 19x8.5 front and rear with like a 22 to 25+ offset. I would love air or coilovers but not for my daily...too expensive.
Old 07-05-2019, 04:21 PM
you still will have to play with the variables to get them to fit.
madtraction39
05-14-2008 09:26 PM
Trunger
04-17-2008 08:51 AM
Colt45
1G TL (1996-1998)
05-15-2007 07:05 PM
tumas
03-18-2004 09:00 PM
Quick Reply: Wheel offsets
