Tail lights stay on
Welcome to the forums.
This thread has been moved from the Second Generation TL (1999-2003) Forum to the car specific forum applicable to your vehicle.
I2canfix (11-08-2020)
definitely brake light switch.
Should be this I believe...
https://www.oemacuraparts.com/oem-pa...QtYXV0b21hdGlj
Or if the switch appears to be in okay condition but this pad broke: https://www.oemacuraparts.com/oem-pa...9tYXRpYw%3D%3D
It prevent the switch from being depressed as well.
for a car that old, I'd opt for that cheaper option as well..
justnspace (06-07-2017)
when you say rubber grommet, do you mean the one touching the pedal? it sounds like that is the issue. get under the steering wheel and look up. you will see it. Brake or Clutch Pedal Stop Pad 46505-SA5-000 for Honda/Acura
SoL_TeK
02-04-2017 07:04 PM
N1h1l1ty
01-19-2017 11:19 PM
