Power windows switch - AcuraZine - Acura Enthusiast Community
Notices
Old 03-08-2019, 02:50 PM
Registered Member
The power windows switch in my RL are not illuminated when I turn the lights on. I don't remember if it is or not from factory...do you know?
Javier75 is offline
Old 03-08-2019, 03:57 PM
Registered Member
2000RL's Avatar
Yes, the window switches should light-up when the lights are on.
2000RL is offline
Old 03-08-2019, 05:50 PM
Registered Member
So, I have a problem, all my doors windows switches are not lighten up. Where do I start to look? Fuse, relay?
Javier75 is offline
Old 03-09-2019, 09:05 AM
Registered Member
OLD_HATCH's Avatar
The bulbs are probably out.
You have to remove the door panels to replace. Might as well see if you can find some LED ones.
OLD_HATCH is offline
Old 03-09-2019, 12:48 PM
Registered Member
Thank you. I think that I don't need to remove the door panels to replace, just gentle take the trim panel out with a plastic pry bar. What do you think?
Javier75 is offline
Old 03-09-2019, 04:03 PM
Registered Member
OLD_HATCH's Avatar
If you try to take the window switches out by prying them you will break both switch and panel.
The window switches are screwed in from the back.
You "MUST" remove the door panel to change the bulbs on the power window switches.
Old 03-09-2019, 05:57 PM
Registered Member
Ok. I understood. I'll remove the door panel first. Thank you for the advice!
Javier75 is offline
know610
3G MDX Discussion (2014+)
02-02-2017 06:16 AM
thx1138
Third Generation TL (2004-2008)
08-12-2011 12:11 PM
96teeluxury
First Generation TL (1996-1998)
11-20-2006 11:11 PM
Amoeba
Technology
12-13-2005 11:37 PM
GOOSE
Ramblings
137
08-15-2003 10:18 PM
Quick Reply: Power windows switch
