Notices
P1491 EGR code on 2002 Acura RL
Old 09-18-2018, 06:17 AM
New Member
I have a 2002 Acura RL that has about 267,000 miles on it. Still going strong, but the CEL threw a P1491 code (EGR valve). I've seen write ups of what folks who had a P0401 code did to clear their problem (pull the manifold to clean carbon buildup, clean EGR valve, clear by-pass pipe). But, with a P1491, what's the best tact to take? Same thing as P0401?
Rhubarb33 is offline
Old 09-18-2018, 06:24 AM
Received 13,980 Likes on 10,384 Posts
well, yes. the code is specifically calling for the EGR valve. check it!
justnspace is offline
Old 09-18-2018, 09:36 AM
Registered Member
My 98RL is now at 245k. Had intake manifold removed and properly cleaned 10 years ago at 165k miles. Have had P1491 (EGR insufficient lift detected) occur about 6 times since, with the most recent being 18 months ago at about 220k miles. I just logged the occurrence and cleared the code with my code reader. Don't think it's anything to worry about unless it becomes persistent.
RL98 is offline
Old 09-18-2018, 10:42 AM
New Member
Well, when I take it for inspection come November, the inspection folks won't pass my car if there are any codes (Check Engine) showing.
RL98: How difficult did you find removing the manifold to get to your EGR and bypass pipe? I've seen the write-ups. I dread doing open-heart surgery, but feel I probably need to, considering I have never done it. Typically, RxP (from Autozone) clears most dealing with the exhaust system. But so far, not this one. I might try BG44K as a last-ditch effort before doing the nasty deed.
Old 09-18-2018, 11:02 AM
Registered Member
RL98 is offline
Rhubarb33 (09-18-2018)
Old 12-06-2018, 07:37 AM
Registered Member
Honestly the EGR valve is just there to meet emissions regulations. It may affect gas mileage but if it does itíll be marginal. Itís an easy repair though, so if you care about the minuscule impact youíll have in the environment, go ahead and pay the $70 for a new one. Itís on top of everything. Just two nuts and a wiring connection and a vacuum hose. 10 minute job, just make sure you donít drop the nuts down onto the transmission cause youíll never get them back (speaking from experience). Just make sure you get a new gasket with it or youíll keep throwing a code.
If you dont donít want to waste $70 then all you have to do is live with the engine light staying on and maybe stop at autozone to read the codes every few months to make sure something new doesnít pop up.
Zzzz is offline
danielsuchit
1G TL Problems & Fixes
07-22-2011 05:14 PM
zyx345
1G CL Problems & Fixes
04-24-2010 01:20 PM
Mach30SiR
First Generation CL Discussion (1997-1999)
19
06-26-2006 10:38 PM
njlss
17
03-11-2006 12:25 AM
uncsuperman
Second Generation TL (1999-2003)
06-13-2005 09:54 AM
Quick Reply: P1491 EGR code on 2002 Acura RL
