Go Back  AcuraZine - Acura Enthusiast Community > AcuraZine RL/RLX Community > First Generation RL (1996-2004)
Reload this Page >
my 2000 acura rl radio stop working when i tried to plug my charger in the lighter
Notices
Old 04-03-2015, 06:38 PM
Registered Member
Went to stick my car charger in the lighter socket and the little spring at the end of the charger fell into the socket, when i went to pull it out, the radio shut off and the dome light won't come on, and the anti theft light started blinking. I checked both radio fuses under the steering wheel and in the hood. Both look fine, the dome light fuse was blown under the hood and i changed it and still does not come on.
Anyone have any other suggestions?
acruaman is offline
Old 04-07-2015, 08:21 PM
Cajun Gumbo Man
Fabvsix's Avatar
You should ONLY use the charger outlet in the arm rest compartment and NOT the lighter! You blew a fuse....did you look in the motor compartment and check all the fuse boxes there?
Fabvsix is offline
Old 02-05-2019, 07:42 PM
New Member
I am having this exact same issue. I assumed I blew a fuse but I can not find a burned out fuse. I swapped out the likely ones anyway just to make sure to no avail. Also I noticed the radio comes alive when I push the instant button but shuts down again as soon as the instant shuts down. Anyone experience something similar?
ryan miller is offline
Old 05-12-2019, 03:13 PM
New Member
I'm having this issue as well. I checked all the fuses and no luck. Any help?
acuraowner8801 is offline
mada51589
05-10-2019 02:17 PM
handsom-hustla
11-13-2015 05:04 PM
kuzdu
Fifth Generation TLX (2015+)
09-10-2015 08:42 PM
Mike Bertram
Second Generation TL (1999-2003)
09-10-2015 09:27 AM
dlknight
09-03-2015 07:54 PM
Quick Reply: my 2000 acura rl radio stop working when i tried to plug my charger in the lighter
