KA9 96-04 Acura RL suspension guide
Old 07-20-2010, 01:03 PM
OLD_HATCH's Avatar
info I've gathered from other fellow KA9 owners. Sticky maybe?
1. You can go super baller and get some KA9 JIC (or the like) coilovers etc shipped in from Japan. This is $2,000.00+.
A short list is:
Buddy Club
Algernon
JIC..............http://www.jic-magic.com/ViewProduct...10&CarMakeID=1
Ennepetal
Aistar
Kamikaze (Specifically made to drop your car STUPID low, shocks are short stroke and springs are really stiff)
AIMGAIN
Insurance
and the list goes on and on.
2. you can get lowering springs shipped in From companies in Japan. This is about $400.00+
3. You can get lowering springs from Europe shipped in. H&R actually has an application on theyre Europe site. Lowers the RL 1.25 inches with H&R quality. Found on Ebay with shipping from Europe for about $365.00+
H&R Europe part number 29844-2, lowers 30mm (1.2")
AP Springs (read wasnt that good) part number FS50-043 lowers front 40mm and rear 30mm (1.6"F and 1.2"R)
4. You can use 91-95 Legend coilovers (ksports etc) you just have to find the front pinchforks fro the fronts out of a Legend from a Junkyard etc. This usually runs in the $800.00 range
5. You can use 1st gen TSX coilovers as well. I believe from what I read the rears need a slight spacer on the bottom through bolt and the fronts should bolt in no probs. You also have to use your own top hats as in the lower model teins etc. This usually runs in the $800.00 dollar range as well.
6. You can always do custom air setups or hydraulics but usually alot more money is involved depending on what systems you choose and does the customizing for you.
Once upon a time Eibach and comptech made springs for the RL. They are no longer made or available unless you find used or some new old stock somewhere. Here is that info just incase.
*NOTE ITEMS IN RED NO LONGER AVAILABLE*
Eibach Prokit for 96-98 Acura 3.5RL
Part # 4037.140
Lowers Front: 1.2 Rear: 1.0
Comptech Sport Springs for 96-00 Acura 3.5RL
Part # 110-140
Lowers: Front: 1.5 Rear: 1.2
I cant seem to update the first post, but just wanted to add that Megan Racing and BC coilovers now make full bodied coilovers for us.
The following 3 users liked this post by OLD_HATCH:
Beatindastreets (03-04-2014), Ken1997TL (06-06-2011), RL-nation (01-16-2014)
Old 07-21-2010, 04:03 AM
Ken1997TL's Avatar
Received 2,328 Likes on 1,308 Posts
Thread stuck!
Old 07-21-2010, 02:53 PM
l.bo's Avatar
thanks for the info, it really help
Old 07-21-2010, 02:56 PM
l.bo's Avatar
you said we can use the 91-95 legend coilover, but can I use the lowering spring instead becuz I don't want it too low, is it possible to do that, thanks
Old 07-21-2010, 03:11 PM
OLD_HATCH's Avatar
yes. 91-95 Legend springs can be used on the 96-04 RL as they are almost exactly the same dimensions.
The difference comes in spring rates as the RL is a good 500 lbs heavier than the Legend. Most of the difference is in the rear so usually the rear springs are a bit too soft.
so just beware that fact if infact you use Legend springs on the RL.
Old 07-29-2010, 12:03 PM
l.bo's Avatar
i found a set of used eibach spring for 96-98, base on what you said I think it will fit my 02 right, just want to double check before i purchase it, thannks
Old 07-29-2010, 12:09 PM
OLD_HATCH's Avatar
yes it will fit.
Old 08-02-2010, 12:48 PM
l.bo's Avatar
thanks, i really appriciate your help
Old 08-23-2010, 02:12 AM
9th Gear
chubbz916's Avatar
YES !!! i cant believe this thread is here haha. I bought my RL that had lowering prings from eibach, words from the seller, get the part # checked out because come to find out the spring's circumfrence is to small. the guy put honda civic springs on a RL!!! what an idiot. i have been looking all over for a solution. do they make stiffer struts just incase i wanted to use the legend springs?
Old 09-12-2010, 07:18 PM
3rd Gear
jrobatl's Avatar
will stock legend coils give u any drop? if not what size coils would u suggest on a 18or20" wheel?
Old 10-12-2010, 12:31 AM
l.bo's Avatar
old hatch, your body kit look sick man, would you tell me where got them from and how much because I want to order one like you, thanks
Old 11-18-2010, 03:37 PM
temps425's Avatar
old hatch, in your experience, what do you think would be the best lowering spring/shock combo for improving performance while maintiaing a smooth ride? Could you post some links? I'm having trouble finding these lowering springs from Europe you speak of...thanks
Old 11-18-2010, 07:36 PM
Universal Soldier
thaillest30's Avatar
I know and understand this has been beaten literally to death but will just the coilovers made for the TSX work for the RL (97 to be specific)?
Old 04-17-2011, 04:49 PM
6th Gear
eshofuniwon's Avatar
i used first gen coilovers from a tsx and have been super happy with the purchase, the rears did need a spacer for the bottom through bolt. but well worth doing, better than lowering springs for sure! i bought some black works knowing they were not the most expensive but very happy with the purchase! i can no longer see the tops of my tires.
Old 04-17-2011, 05:11 PM
6th Gear
The following 3 users liked this post by eshofuniwon:
jayess058515 (09-21-2012), Rex Kramer (05-10-2017), timeizmoney22 (07-15-2013)
Old 04-17-2011, 09:36 PM
3.5RLv-tec?'s Avatar
Love it. Is the BlackWorks racing coilover non damper one? How is the ride comfort compare to stock, bouncy or rough?I'm planing to get a coilover pretty soon, and I thinK i'll get the Tein basic $800 plus a camber kit. Can you explain to me what kind of spacer or size do I need in the rear or I just take in to the shop and they know what to do. I need more information on this. BTW how many inches did you drop.
Old 04-17-2011, 09:45 PM
OLD_HATCH's Avatar
I believe number 5 is all that's needed for the tsx coilovers
Old 04-18-2011, 10:25 PM
cool thx, it's time for me to save for the coilover, I think it going to be another year or so
Hey eshofuniwon, how is the Blackwork coilover, and how many inches did you drop?
Old 05-07-2011, 01:24 PM
OLD_HATCH's Avatar
I wanted to add a note.
IF your planning on going with some wide high offset rims you will need to go the TSX route. The coilovers will give you more clearance than trying to go with springs from either a Legend or RL.
Old 05-18-2011, 10:08 PM
RL STATUS's Avatar
"5. You can use 1st gen TSX coilovers as well. I believe from what I read the rears need a slight spacer on the bottom through bolt and the fronts should bolt in no probs. You also have to use your own top hats as in the lower model teins etc. This usually runs in the $800.00 dollar range as well."
i was wondering if you had any specific set of instructions for the rear, as far as pulling the seat out or something, and aside from the spacer. i just picked up form and function coilovers for tsx. please let me know. thank you!
Old 05-18-2011, 10:49 PM
OLD_HATCH's Avatar
You do not need to take out the seat. Simply pop off the speaker covers and remove the speakers to access top of strut.
Old 05-19-2011, 08:40 PM
RL STATUS's Avatar
thanks for the heads up. this might sound like a stupid question, i know that our RLs are 200-400 lbs more than tsx, i was wondering whats a good setting for a job on 19s, im not planning to slam like crazy, i dont want to rub thats for sure. but obviously if the cars heavier on a good tsx setting, it will be lower on the RL which is why i asked. i know its kinda hard to answer haha but if you could the best u can or what youre knowledge is of that , id be thankful. thanks
Old 05-20-2011, 08:11 PM
OLD_HATCH's Avatar
Actually since the springs are linear rates they have no problems on the RL.
As far as rubbing, that depends on alot of variables like rim size/offset, tire size, camber, etc etc.
Old 05-25-2011, 09:31 PM
RL STATUS's Avatar
thanks for your responses,so when you mean linear rates, the height wouldnt be too off compared to tsx? and i also wanted to ask you when you say use the tophats, do we use all 4 of the oem tophats or just the front?
Old 05-26-2011, 07:26 AM
ryk
ryk's Avatar
RL Status - your avatar is what I want my car to resemble. Tis a pity I can't source that lip kit or spoiler anywhere.
Old 05-26-2011, 08:13 AM
OLD_HATCH's Avatar
when I say linear rates I mena the way the spring compresses. Look up linear vs progressive rates.
The lower end teins and some other brands require you to use your oem tophats. there are some than come with them. you want the kits that utilize hem oem tophats to make it basicly a drop in option.
Old 05-28-2011, 04:02 PM
6th Gear
sorry for the delay,, i believe i did about 2.5 in the front and 2.75 in the front but it seems to be level. the damper is set right in the middle, not to soft or not to stiff, real happy with the ride, the whole purchase. looks great rides smooth and no tire rubbing, i had them about an inch or so lower but a had tire rubbing, but it looked great! now i have it at the perfect ride height for my needs....perfect daily!
Old 06-10-2011, 09:16 AM
Universal Soldier
I need a little advice on choosing which set of coilovers. I've narrowed it down to..
K sport
Tein (the green color is wild)
Megan
Blackworks
D2
Any guidance would be greatly appreciated. Thanks all
Old 06-10-2011, 04:14 PM
Cool, thank for the info. Anyway, have you put on camber kit? I just wondering because I've planned to lower my car too ( no tire gaps). Did you feel the car shaking because a lot lowered RL owners are complaining about it.
Old 07-13-2011, 11:19 PM
RL STATUS's Avatar
anyone happen to have a DIY for putting in tsx/accord (using OEM tophats) coilovers?
Old 07-15-2011, 09:55 AM
OLD_HATCH's Avatar
Look for any strut changing diy.Basicly the same. The lowered priced coilovers usually don't come with built in top hats, but that varies by manufacturer and product line.
Old 07-15-2011, 07:24 PM
RL STATUS's Avatar
so theres nothing i have to look out for, or do specifically? im just wondering is all cuz this is my first time doing it myself with friends. Your input is appreciate. thanks
Old 07-17-2011, 09:25 PM
Universal Soldier
Just got my coilovers. I bought the Megan racing coilovers, they have the top-hats and dampening adjustment. I should have it completed by the end of the week provided the weather. Wish me luck!!!
Old 07-18-2011, 01:24 AM
Good luck man. Damn, you are faster then me! I just have enough saving for the coilover now I have to deal with the ABS pump and the EGR problem
I can't want to see the result!
Old 07-18-2011, 08:26 AM
Universal Soldier
Sure thing bro! Next after the coilovers would be the EGR cleaning and some paint, and that should do it fo me.
Old 07-18-2011, 01:11 PM
Universal Soldier
Just found out they sent me a set of coilovers for a 03-07 Honda Accord. I specified TSX 03. Its 95 degrees outside, Im tired and heated. Can you blame me? lol
Old 07-19-2011, 05:35 PM
RL STATUS's Avatar
sup man, good luck! lemme know how it goes, im planning to put mine in soon as well. mine are also tsx/accord coilovers but no dampening control. be sure to take some photos man!
Old 07-19-2011, 08:52 PM
Universal Soldier
Ok definitely will do. Im going to use the old top mounts, so I should be close to finished by tomorrow but I dont know I still have 2 papers to write and Im not motivated at all to write anything!
Old 07-20-2011, 12:40 AM
silver3.5's Avatar
Maybe someone might want to add that Eibach springs for the 91-95 Acura Legend can be used for G1 RLs without any modifications?
Old 07-20-2011, 03:11 AM
9000revs's Avatar
I would like some more info on this. Can you provide a link to someone who has done this? Thanks.
Quick Reply: KA9 96-04 Acura RL suspension guide
