Timing Belt + Water Pump Kit Help
Old 03-22-2015, 05:41 PM
jaydubz's Avatar
Water Pump
Timing Belt
Balance Shaft Belt
Camshaft Belt Tensioner
Balance Shaft Tensioner
2 Camshaft Seals
Crankshaft Seal
Pre-Assembly Seal Lubricant
Is this all I need for your standard TB/WP Kit? Am I missing any parts?
Price is $132 from Dayco.
http://www.rockauto.com/catalog/more...id=458&jpid=11
Link for reference.
Old 10-06-2015, 06:02 PM
legend921's Avatar
That's the kit. While you're at it I would check the Thermostat as well and just do a cooling system refresh.
Old 10-06-2015, 08:11 PM
jaydubz's Avatar
Hey thanks for the reply, all the parts fit perfectly, they checked out the thermostat and said it was fine and they did a coolant drain and fill with honda 50/50. So now I am good to go for about 90k more miles, woot.
redsox68
09-16-2015 06:18 PM
merc009
09-14-2015 06:43 PM
whitesoxsfan12
09-07-2015 04:07 PM
asahrts
09-04-2015 05:55 PM
Quick Reply: Timing Belt + Water Pump Kit Help
