Diy For Acura Rl 1996-2004
Hi i'm looking for a DIY with photos of acura rl 1996-2004 timing belt water pump replacement, So Far after extensive research, i'v found DIY for tl but i'm not sure if it's the same or about the same, if anyone knows of any please post it.
Thank you.
Thank you.
If you have any experience with timing belts its pretty much the same. Just set all timing marks. Make sure you replace any orings for the waterpump. And set the timing marks on the balancer shaft. If you dont have the service manual I can link one for you.
Also, do you have the special tool for the crank pulley? This one in fact.
cycdaniel
12-17-2019 10:58 AM
Skirmich
09-15-2015 06:41 PM
