Bose Speaker Help Info Needed
Old 08-01-2006, 04:55 PM
killakill's Avatar
hello i made a post long time ago about my speaker anyways the driver side rear speaker does not work i have no idea why i had the car l ike this i chkecked to see if the speaker is blown it is not so im wondering what colour wire is the bose speaker wire? further more i found a wire that is not connected it is pink with a lil black stripe and the pother wire is solid black they both go into a green plastic hook up thing please help
Old 08-01-2006, 06:47 PM
kollamala's Avatar
driver side speaker wire
I had the same problem in my honda odyssey. I reconnected the wires and its okay. In my case it was working and probably got loose. Color of wires were different but an easy way to check would be to check other door to make sure the wire that is not connected is indeed the speaker wire.
Old 08-02-2006, 03:12 AM
killakill's Avatar
biger problem
thanks i figured its my speaker wire after experiments i basical;ly disconnected another adapter tht was green it turned off the front speakers so i assume all green connector things are for the speakers now the hardest thing is there is no spot for that green adapter to be plugged into ???? i dont know where to plug that adapter i looked in the vicinity and there was nutin?
oo7spy
06-19-2023 12:48 AM
notfast
1/2G MDX (2001-2013)
03-28-2023 08:10 AM
02-25-2020 09:57 AM
sockr1
10-01-2015 01:31 AM
iRaw
ILX
09-05-2015 12:10 AM
Quick Reply: Bose Speaker Help Info Needed
