2000 3.5 RL Front lower ball joints
Hi Everyone
Can someone tell me if the front lower ball joints for a 2000 RL can be pressed out and replaced as opposed to replacing the entire knuckle which is expensive. If so does moog supply a set foe them or is it another supplier
thank you
thank you
Be a better driver
Doesn't look like it the way it is shown in the below parts diagram. Which may explain why the dealer wants $250.
http://www.oemacuraparts.com/auto-pa...t/knuckle-scat
Same with the generation after yours: https://acurazine.com/forums/tires-w...t-play-938887/
BluNosr2
11-19-2015 12:37 PM
russianDude
1G RDX (2007-2012)
11-16-2015 09:44 AM
