Acura TL 98 3.5 SE
Old 03-11-2019, 05:56 PM
Excel The Artist's Avatar
Acura TL 98 3.5 SE
I recently put 20 inch rims on my RL . However when I go over bumps the back right tire scraps. It is only that tire I am having a problem with. I had the back struts replaced but cannot find the coil spting for the back. What should I do about the coil spring? Would spacers fix the problem? Is there another Acura with similar parts? I'm lost need help. It also happens when I turn left . No other tires are having this problem.
Old 03-11-2019, 06:36 PM
Latent car nut
horseshoez's Avatar
Received 2,005 Likes on 1,407 Posts
Which car are you talking about, a TL or an RL?
How about opting for a more realistic wheel and tire combination?
Assuming you're talking about an RL and assuming the offset of your wheels is correct, a 225/35 R20 should fit with no issues (but it will look silly).
Old 03-11-2019, 09:05 PM
Received 16,260 Likes on 11,971 Posts
perhaps get an alignment and add camber to that side.
aznbo187
09-05-2010 10:41 AM
kronahan
1G RDX (2007-2012)
42
06-05-2008 08:40 PM
thealliance15
11-19-2003 05:22 PM
Quick Reply: Acura TL 98 3.5 SE
