AC/Dashboard making a knocking sound? - AcuraZine - Acura Enthusiast Community
Notices
Old 08-01-2018, 10:30 PM
Registered Member
My 98 RL with 270k miles on it was making a weird noise coming from somewhere in the AC vents or maybe the dashboard/firewall. I drove about 25 minutes across town and when I got home I turned the car off and pulled my phone out to reply to a text. About 45 seconds after I took my key out of the ignition I started hearing a knocking noise from that area. I have a video on twitter that you can watch
with a decent sample of it. Again, car was off, no accessories were on except for the AC mode display on my dashboard, which I think is always on for some reason. Iíve never heard this noise before and want to figure out if itís an issue. By the time the noise started all of the fans/motors would have stopped rotating (I would think). If anyone has any ideas what it could be it would be much appreciated if you could share them. Thanks!
btw, I had the AC on 68 degrees Fahrenheit and the air temp outside was around 80 I think. AC was somewhere between medium and full blast. Including all details I can think of in case theyíre relevant. Thanks again.
Zzzz is offline
Old 08-24-2018, 08:36 AM
New Member
Hey. I think it may by the Air Conditioner Servo Motor, probably the Air Mix Servo. Try manually selecting the Air Mode in the different positions (Such as Centre Vents, Bi Level, Floor Level, Defroster) and see if the air comes out correctly in each position.
Also try the temperature setting and slowly change the temperature and see if cold/hot air is coming out correctly to the temperature displayed on your climate control.
I am not sure about how to remove the Servo, but I am sure it is in the repair manual? I would try these first to see if you can locate which AC Servo Motor is the problem.
And I don't think it is normal for the AC Mode to be displayed when the car is off? This is why I am thinking it might have to do with the your AC Electrics/AC Servo Motor.
Let me know what you are able to find out.
rangeroverhse8 is offline
Old 08-26-2018, 05:31 PM
Registered Member
Thanks for the help, I found that air is constantly coming out of the top vent to the left of the steering wheel and the top passenger side vent, no matter what mode itís set to. The top center vent opens and shuts correctly according to what mode I have it set to, as do the floor vents. Itís currently 90 degrees outside which may affect what temperature Iím feeling coming from the vents, but it feels like it blows colder than it should until I turn the temp knob all the way up. Thereís a very distinct difference between setting it to 89 degrees and setting it to 90, and anything between 60-80 feels colder than it should and then it starts to feel more accurate above 80, but again, it could be just relative to how it feels outside. I also couldnít feel a huge difference when I turned it from the high 70s down to 60 again. I should be testing this with a thermometer but since I donít have it, my guesstimates will have to do. I recently bought a service manual (Iím doing head gaskets Labor Day weekend) so Iíll refer to that to figure out where the servo is. As of right now itís not a major issue, but the noise did freak me out because itís new. I just wanted some ideas as to what it could be. Thanks again for your help, let me know what you think.
Zzzz is offline
GotdatTSX
First Generation TSX Discussion (2004-2008)
22
09-03-2017 10:17 PM
HacksawHilliard
Third Generation TL (2004-2008)
40
01-16-2012 06:22 PM
Nedd
First Generation TL (1996-1998)
09-20-2006 02:16 PM
buzzardrocks
Second Generation CL Discussion (2000-2003)
10-25-2002 09:41 AM
Nicky Pass
40
06-05-2002 11:22 AM
Quick Reply: AC/Dashboard making a knocking sound?
