VSA Light on
VSA Light on
Greetings everyone,
I have an '02 with out Navigation. I have recently had to renew my registration and after fixing code after code, I was able to pass emissions. In the process, I had to replace my Cat. I did so with a Magnaflo hi-flo cat. Now, I have recently added an intake. My problem is now my VSA light is now on. I used a buddy's code reader and I am getting the same code that let me know my CAT was clogged. (catalyst below threshold. I have tried to reset this with no luck. I have checked all the intake connections and I have no leaks. I am wondering if I get a better muffler (freer flowing like an Ansa), will this solve my issue. Has anyone else with an intake have this problem? I have tried to search this but it seems just about everything related to VSA and an intake take me to the TL. I hope someone can offer some advice.
Thanks!
Thanks!
Are you sure you don't mean the "Check Engine" light? The VSA light deals with traction and stability control and the like. The cat would fall under a check engine light.....
My friend said that he has a friend that had the same problem but on a different car. He said he put a restrictor in his intake because it was getting too much air? To me that didn't make any sense since that's the point of more air. Thats why I ask. Thanks for answering my by the way. your time is appreciated.
No problem, well it sounds like you have some type of brake/abs/stability/traction control issue as well. The check engine light might be due to the cat issue, however you are having other problems besides that. The average code scanner a person has cannot read the VSA code, you need a special scanner for that that usually the dealer has (and a few independent shops as well possibly). You should try and get these codes as well. That way, you'll have a clearer picture of what exactly is going on and what you should focus on first.
Have you tried to put the old intake back on and see if the code is still there? That way, you can narrow down the causes. The 420 code has a variety of things that can cause it. I would put the original intake on and see if the code goes away. And the VSA has nothing to do with the CAT, nor do the ABS and Triangle light.
I would have done that but I got rid of it after everything seemed okay with the intake. I am guessing that the VSA is on due to something being loose (hose) I will have time today to check it out. Thanks for your help. I'll update after if figure it out incase anyone else has a problem in the future.
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
