Notices
2002 RL SRS light on
Old 11-29-2018, 08:37 PM
New Member
My 02 RL3.5 Red SRS light is on after the "side air bag" yellow light flashed a few times occasionally. I am not sure how to turn it off or what the fix may be. Any help is appreciated. Also, Not as important however just like the 98RL that I had occasionally when turning the key to start the car nothing happens and have to turn off/back on until it starts. The previous owner had the same issue and had the starter replaced. It looks like that didn't help.
Acura1897 is offline
Old 12-01-2018, 11:12 AM
Registered Member
2000RL's Avatar
The not starting all the time may be something as simple as corroded battery terminals or cables. It pays to check the simple things first, however, with the SRS light/side airbag issue if you don't have a code scanner I would go to an auto parts store. I know Autozone, Advance Auto, and Pep Boys stores will scan your car for codes for free and they may find a fault code set for the SRS system.
2000RL is offline
Old 12-02-2018, 07:39 AM
Registered Member
Could be a slow recognition of the key by the theft protection system. Try turning to the "on" position then waiting for a couple of seconds prior to turning to "start". I've had this behavior for the past few years with my 98 RL, and several others have reported it also.
RL98 is offline
wadinson
Acura RSX Discussion
03-20-2016 12:08 AM
WhySoAsian
08-10-2014 02:09 PM
jhus849
02-06-2014 05:32 PM
twiskus
03-08-2009 04:56 PM
Quick Reply: 2002 RL SRS light on
