2000 RL canister purge valve
Where is the location of the canister purge valve on a 2000 RL and does it go by any other names like "shut valve", "two way valve", "vent valve", etc.?
Also, if you know the answer to that question, then you will know how to tell me to remove the plastic rivets from the cowlings that cover the area I believe must contain the canister.
Thanks, Scott
Thanks, Scott
Welcome to the forums.
This thread has been moved from the First Generation RL Photograph Gallery Forum to the sub forum more applicable to your topic.
I also deleted your other almost identical thread in this same forum and the thread you posted in the 2G TL Forum.
