2000 rl abs relay
2000 Acura 3.5RL w/ Navigation
I have a manual that shows the ABS Relay in the under hood fuse box but when I looked on the cover of the under hood fuse box it just shows a blank square with a diagonal line through it and is not marked ABS RELAY. In the spot that is supposed to be for the ABS Relay there is only a blank white cover . When I lift the cover off there is a jumper underneath that connects the two large terminals and nothing connecting the two smaller terminals. Does anyone have any idea where or how to find and test the ABS RELAY on this 2000 Acura 3.5RL w/ Navigation? My ABS, VSA, and EXCLAMATION, lights are all on. Thanks in advance for any help I can get. |
Ok, so as I was looking more closely to the manual that I have I see that the ABS Relay was included prior to the 2000 and that my year has a "short bus" instead of a relay. That being said I have made copies of the trouble shooting pages and will pull the DTC's and trouble shoot the ABS light this week depending on the weather. Hopefully just an ABS sensor or something simple like that. If all goes well then maybe the VSA light will go out as well.
Hey I know it's been a while. Did you ever figure out the relay issue? I'm having issues with all VSA, ABS and exclamation lights on as well. Code is 52-01 for "ABS pump motor relay open circuit" if you have any input please let me know! Thanks in advance
