2000 RL 3.5 Navi cranks but wont start
My car is cranking but wont start replaced fuel pump relay nothing could it be the fuel pump?
Welcome!
Check the main relay as well. |
Originally Posted by Isaac Galindo
(Post 16410472)
Thanks, Tahbit |
Following this post
I have a similar issue on my 05 RL one night I went to get air in the tires put gas in it went to 2 stores and on the way home the car just died while slowing down to make a turn into the street I live on.
the car cranks but doesn’t start, I recently replaced the plugs and coils back in August and the timing belt has roughy 5 to 6k on it. The fuel pump wouldn’t turn on so I replaced relay and then the pump, the battery then wouldn’t hold a charge I replaced the battery as well since it was close to 6 years old. The car still Just cranks over and doesn’t start it wants to start. Everything turns on lights navigation air etc just turns over. I went through and disconnected the fuel lines to see if it’s getting fuel and it is. Spark I don’t know there is nothing to ground so see if it’s getting a spark. Im going to try a old trick with the coil and spark plug to see if it’s getting a spark when I get home. there is No check engine lights, I unplugged the MAF to see if there is a issue with it reading error codes, but it Came up with the MAF error. I called the dealership and they are also stumped. they said check the crankshaft sensor and the timing belt. But the timing belt is new. I don’t think the 05s have a main relay I couldn’t find it anywhere or anywhere online. did anyone get a fix for this? |
