Are you guys Ready?
About my RDX...
My RDX as 280000km (174000miles) And as with no trouble beside the wastegate on the turbo. Now in my garage waiting for me to reinstall the Turbo. Always used regular gas because never noticed the difference the times I tried Super. Only things not original are breaks, spark plugs, liquids, belt, tires and the compresseur was replaced by Acura under Warranty. Replaced the pressure switches of the Trans. So its pretty much all original, there's no mods in my Car. Very unreliable Acura :thumbsup: |
What?:what:
I didn't understand either.
It really doesn't matter the make or model.... Cars are machines. Machines have moving parts. Moving parts fail. |
amazing.
Originally Posted by Poveiro
(Post 16385375)
About my RDX...
@justnspace @wusty23jd
Sorry for the missing words that made you not understand. @schen72 When I went for the test drive the chief of mechanics came with me, we went and fill the tank and when he used regular he told the computer compensates for explosion time, that was the only difference on gas, that people worry to much (not my words) The super here is expensive. About my RDX... My RDX as 280000km (174000miles) And as had no trouble beside the wastegate on the turbo. Now in my garage waiting for me to reinstall the Turbo. Always used regular gas because never noticed the difference the times I tried Super. The only things not original are breaks, spark plugs, liquids, belt, tires and the compresseur was replaced by Acura under Warranty. (normal wear) Replaced the pressure switches of the Trans. So its pretty much all original, there's no mods in my Car. Very unreliable Acura |
(Post 16385993)
Sorry for the missing words that made you not understand. @schen72 When I went for the test drive the chief of mechanics came with me, we went and fill the tank and when he used regular he told the computer compensates for explosion time, that was the only difference on gas, that people worry to much (not my words) The super here is expensive. About my RDX... My RDX as 280000km (174000miles) And as had no trouble beside the wastegate on the turbo. Now in my garage waiting for me to reinstall the Turbo. Always used regular gas because never noticed the difference the times I tried Super. The only things not original are breaks, spark plugs, liquids, belt, tires and the compresseur was replaced by Acura under Warranty. (normal wear) Replaced the pressure switches of the Trans. So its pretty much all original, there's no mods in my Car. Very unreliable Acura As for the gas, I'm sure using regular gas is just fine for a while but if you want the engine to last into old age, I would rather just use whatever the engineers designed it for. But I'm not an automotive engineer, I have no proof one way or the other. I just don't presume to know more than the Honda engineer that designed the engine. |
Originally Posted by schen72
(Post 16386195)
I still can't understand what you're trying to say. Are you saying because you have to replace items that are meant to be worn out (brakes, spark plugs, fluids) that your car is now "unreliable?" If that's the only stuff you've had to replace, isn't that the definition of "reliable?" It sounds like the only non-maintenance issue you've had is a wastegate problem in 174k miles of driving.
As for the gas, I'm sure using regular gas is just fine for a while but if you want the engine to last into old age, I would rather just use whatever the engineers designed it for. But I'm not an automotive engineer, I have no proof one way or the other. I just don't presume to know more than the Honda engineer that designed the engine. Also lots of people criticize the use of regular gas, I just wanted to show yhat its not the gas and that is very reliable. When I wrote Unreliable I was with a grain of sarcasm. |
I'm glad that your RDX has been reliable. That is good to hear. If you want it to continue to be a reliable car, I also recommend that you start using premium gasoline. Similar to Schen, I am not an automotive engineer, but I like to stray on the sight of caution when it comes to factory recommendations.
I only use top tier gasoline stations usually mobile 93 octane gas ⛽️.
Using lower octane can ruin your motor, we need it because it helps to reduce knock with the compression were running in our high performance motors. https://cimg4.ibsrv.net/gimg/acurazi...b6cde1a94.jpeg This is why you should get top tier gas ⛽️ I use mobile 93 only in my 09’ RDX. https://cimg5.ibsrv.net/gimg/acurazi...d07540ca6.jpeg More reasons to use it is that the manufacture of our vehicle recommends it. |
My personal philosophy is that if you're leasing or you know you're not going to keep the car for more than 5 years, using regular is fine. By the time any problems develop, it won't be your problem anymore. If you keep cars a long time, like myself, use premium (or the rating the manufacturer recommends). I kept my 99 TL for 18 years.
(Post 16387129)
What I wanted to say to some that have been asking is that the car is very reliable.
(Post 16387605)
The sarcasm doesn't come across easily in forum posts.
^^this, but I got it. |
(Post 16387604)
