Notices
Washer Fluid leak
Old 12-30-2018, 04:39 PM
Registered Member
Washer Fluid leak
Seems like exact symptom as this tsb. Should I try asking for goodwill as TSB suggests? Seems like dealer can do it cheap and quickly ($15 parts).
https://honda.oemdtc.com/TSB/B08-023.pdf
russianDude is offline
Old 12-30-2018, 05:22 PM
Registered Member
Not sure if its necessary remove fender to re-adjust the bolts. Seems like the neck can be replaced by itself without removing the fender. that maybe good enough?
Old 01-03-2019, 10:43 AM
2006 NBP TL MT6/ 02TL-S
AlanW's Avatar
Mine was leaking badly. It was a broken plastic part right at the pump where it divides the flow into the 2 little hoses for each side. I had to take the bumper off to get at it. I fixed it with some sealant/glue stuff, let it dry for awhile, and it has been good since.
AlanW is offline
Old 01-03-2019, 11:40 AM
Registered Member
my problem is different. Its exactly what tsb say, only leaks at the neck where it connects with reservoir. After level drops bellow neck it stops leaking.
seems like there is a defect in original part and Acura has updated part for the neck.
Old 01-03-2019, 01:49 PM
Received 5,934 Likes on 4,758 Posts
If there's a TSB, just take it in
thoiboi is offline
Old 01-03-2019, 02:12 PM
Registered Member
yeah, surprisingly tsb says that service manager may consider it for good will.
Old 01-05-2019, 06:34 PM
Carmine S.
CSmoney28's Avatar
Happened to me, I had to get a new tank...
CSmoney28 is offline
Old 01-05-2019, 06:53 PM
Registered Member
Why new tank, the TSB says to replace the neck? Is this a different issue?
Old 01-05-2019, 08:08 PM
Carmine S.
CSmoney28's Avatar
My tank ended up being cracked...
BartmanEH
18
02-01-2016 06:37 AM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
jakevogel
1G & 2G MDX Discussion (2001-2013)
12-16-2013 09:17 AM
vtec1jk
Second Generation RL (2005-2012)
24
02-21-2007 07:53 PM
Quick Reply: Washer Fluid leak
