RDX Service Manual
#42
StayAtHomeDad
Originally Posted by sasair
You can shift to S mode at anytime, at any speed. When you initally move into S mode, you are in automatic so it will select the appropriate gear for you. then you can start shifting manually from there if you want.
yes you can downshift on the freeway doing 65mph. I'm pretty sure 3rd gear will handle 65 mph just fine, but I don't know about 2nd.... the manual says you can take 3rd gear up to 94mph, 4th gear up to 114mph. That's on page 302...
#44
I got my RDX service manual in the mail today. Wow what a book! To say it is phone book sized would make it sound smaller than it really is I think. I almost have trouble picking it up with one hand. If anyone needs any info from it, let me know... It looks to cover everything you can imagine. Except of course all those features that aren't there that we would like....
#45
sasair, is there any info in the rdx service manual how to switch readout from fahrenheit to celsius and from miles to kilometers? (maybe this can be done through some key combinations etc...)?
thnx
thnx
#47
Ukrainian RDX
Shadowx, there's no way to do this from the MID or any other way without interferring the computer. This is done here in Ukraine by some 'magicians' for nearly $150 per trip and almost the same for 200khz radio step.
#49
Help with map lights bulb change (replace with LED).
Good day to all, new 09 w/tech owner here.
I am trying to change out all bulbs inside the car to LEDS. I have done them all but the two overhead ones up front (map lights). I cant seem to get the covers off (or too afraid to get aggressive without asking).
If you could spare a minute and look in that dear wonderful book and help me change out those bulbs I would be very grateful for the help.
Thanks in advance
MM
Thanks in advance
MM
#50
Do you have a list of what bulbs are needed? I have a new 09/tech also
Thanks in advance
MM
Thanks in advance
MM
#51
Thanks in advance
MM
Thanks in advance
MM
A cautionary note: the RDX dome lightbulb is horizontal in the socket and they are a PIA to take out (and put in). You'll see! I used a soft cloth and needlenose to carefully pull it out. Don't squeeze too hard and shatter the bulb.
#52
I was wondering if you could help- passenger mirror light
My passenger mirror light cracked, and I was needing a how to on replacing the light on the mirror- right side. Any help would be much appreciated. Thank you.
