Notices
RDX reliability?
Old 02-12-2019, 08:55 AM
  #81
mrgold35
mrgold35's Avatar
Originally Posted by CSmoney28 View Post
Did you put regular coolant or a sealer coolant? Also, is it possible the cold 🥶 showed a leak in a cracked hose or a cracked in the radiator due to shrinkage? Then warmer temperatures expanded the crack and sealed it back up?
No sealant, I put in about 4 cups Prestone 50/50 left over from my daughter's car (1 cup in radiator/3 cups in dry overfill reservoir to max fill line). It is still bone dry and can't see where the leak came from after +2 weeks. The external RDX anti-freeze reservoir still shows full. Temp are going to get back into the 60s by Friday and I can double-check it then. Might have to remove the plastic cladding under the car to get a better look this weekend at the area at the bottom of the radiator.
mrgold35 is offline
Old 02-15-2019, 12:24 AM
  #82
Carmine S.
CSmoney28's Avatar
Okay, let me know good luck with everything.
CSmoney28 is offline
Old 02-19-2019, 07:32 PM
  #83
Registered Member
Poveiro's Avatar
Go to the auto parts and get a bottle of UV, get a uv flash light and you half way done to find the leak.
Poveiro is offline
Old 05-09-2019, 05:28 PM
  #84
WTF?
Midnight Mystery's Avatar
crxman How many miles do you have on your RDX now?
Midnight Mystery is offline
Old 05-11-2019, 01:17 PM
  #85
mrgold35
mrgold35's Avatar
Update on my radiator leak. Turned out to be a hairline crack at the bottom of the radiator housing. Replaced and back to adding miles to the RDX.
mrgold35 is offline
Old 05-11-2019, 09:42 PM
  #86
WTF?
CL-S progression 01
01-26-2016 04:15 PM
navtool.com
Sponsored Sales & Group Buys
87
01-23-2016 01:25 PM
adrian_s2k
First Generation RDX (2007-2012)
23
01-12-2016 04:25 PM
San Yasin
Second Generation RDX (2013-2018)
21
09-29-2015 10:52 AM
dirleton
09-29-2015 08:26 AM
Quick Reply: RDX reliability?
