RDX Pricing, Specs, Pics & Manuals **Updated 8-1-07**
Added [August 1, 2007]: Acura ServiceNews & Service Bulletins
Added [July 19, 2007]: Download 2008 RDX Navigation Manual here in PDF format
Added [July 19, 2007]: Download 2008 RDX Owner's Manual here in PDF format
Added [March 23, 2007]: Download 2007 RDX Navigation Manual here in PDF format
Added [Jan 26, 2007]: Download 2007 RDX Owner's Manual here in PDF format
Added [Jan 24, 2007]: Click here for a gallery of member pics!!!
MSRP
2007 Model Year
U.S.
Base MSRP: $32,995
w/Technology Package $36,495
2008 Model Year
U.S.
Base MSRP: $33,195
w/Technology Package $36,695
INVOICE
2007 Model Year
U.S.
Base: $30,104
w/Technology Package $33,290
Destination = $670
2007 Model Year
MSRP
Canada
Base MSRP: $41,000
w/Technology Package: $45,000
INVOICE
2007 Model Year
Canada
Base: $37,720
w/Technology Package $41,400
Freight & PDI = $1,775 (Edited May 8, 2007)
2008 Model Year
MSRP
Canada
Base $ 41,400
Tech $ 45,100
INVOICE
2008 Model Year
Canada
Base $ 38,088
Tech $ 41,492
Freight/PDI : $ 1,775
Federal Air conditioning tax; $ 100
PowerTrain
Engine - DOHC i-VTEC Turbo I-4
Displacement - 2300cc (2.3-liter)
Compression ratio - 8.8:1
HorsepowerSAE net @ rpm - 240 @ 6000
Torque SAE net @ rpm (lbs.-ft.) - 260 @ 4500
Transmission - 5-speed automatic
EPA estimated mileage City/Highway - 19/24*
Emissions certification (CARB/EPA) - LEV II ULEV/Tier-2 Bin-5
Fuel type - Premium unleaded
Transmission Specs
Transmission 5-speed automatic with F1(R)-style Sequential SportShift paddle shifters and Grade Logic Control
Ratios (:1) 1st 2.697
. 2nd 1.606
. 3rd 1.071
. 4th 0.766
. 5th 0.612
. Reverse 1.889
. Final 4.533
Chassis
Body Type - All-steel unit body
Front Suspension - MacPherson Strut
Rear Suspension - Independent multi-link
Shock Absorbers - Front and Rear Twin Tubes
Stabilizer Bars
Front - 21 mm diameter
Rear - 19 mm diameter
Steering Type - Torque-sensing variable power-assisted, rack-and-pinion
Steering Ratio - 15.1:1
Steering Wheel Turns (lock to lock) - 2.76
Turning Circle (curb to curb) - 37.4 ft
Wheels 18 X 7.5 JJ cast alloy wheels
Tires - P235/55R18 99V high performance all-season
Braking System - 4-wheel Anti-lock Braking System (ABS) with Electronic Brake Distribution (EBD) and Brake Assist
Front Discs - 11.7 inch (297 mm) diameter ventilated (w/ dual piston caliper)
Rear Discs - 12.0-inch (341 mm) diameter drum in disc
Stability Control - Vehicle Stability Assist (VSA) with Traction Control System (TCS)
Exterior Demensions
Interior Demensions
Front
Weights
Curb Weight - 3968 lbs (1800 kg)
W/ Technology Pacage - 3982 lbs (1800 kg)
Weight Distribution (% front/rear) 52/48
Fuel Economy
EPA Fuel Mileage - City/Highway - 19/24* mpg (City/Highway)
*Preliminary mileage estimates determined by Acura. Final EPA mileage estimates were not available at the time of printing. Use for comparison purposes only. Your mileage may vary.
Towing
Maximum Towing Capacity - 1500 lbs
Capacities
Cooling System - 2.4 gallons/9.1 liters
Fuel tank - 18.0 gallons/68.0 liters
Volumes
Total - 6.09 quarts/5.8 liters
Acura recommends Mobil 1 Synthetic
Penzoil Platinum Plus has also achieved the HTO-06 certification
Country of Origin
United States (Marysville, Ohio)
Please PM me if there is anything else you would like to see added or that is missing.
Road & Track Specifications with performance statistics.
MSRP
2007 Model Year
U.S.
Base MSRP: $32,995
2008 Model Year
U.S.
Base MSRP: $33,195
INVOICE
2007 Model Year
U.S.
Base: $30,104
Destination = $670
2007 Model Year
MSRP
Canada
Base MSRP: $41,000
INVOICE
2007 Model Year
Canada
Base: $37,720
2008 Model Year
MSRP
Canada
Base $ 41,400
Tech $ 45,100
INVOICE
2008 Model Year
Canada
Base $ 38,088
Tech $ 41,492
PowerTrain
Transmission Specs
. 2nd 1.606
. 3rd 1.071
. 4th 0.766
. 5th 0.612
. Reverse 1.889
. Final 4.533
Chassis
Stabilizer Bars
Exterior Demensions
Interior Demensions
Front
Weights
Fuel Economy
Towing
Capacities
Volumes
Country of Origin
asahrts
09-04-2015 05:55 PM
