RDX Pricing, Specs, Pics & Manuals **Updated 8-1-07**
Added [August 1, 2007]: Acura ServiceNews & Service Bulletins
Added [July 19, 2007]: Download 2008 RDX Navigation Manual here in PDF format Added [July 19, 2007]: Download 2008 RDX Owner's Manual here in PDF format Added [March 23, 2007]: Download 2007 RDX Navigation Manual here in PDF format Added [Jan 26, 2007]: Download 2007 RDX Owner's Manual here in PDF format Added [Jan 24, 2007]: Click here for a gallery of member pics!!! MSRP 2007 Model Year U.S. :patriot: Base MSRP: $32,995 w/Technology Package $36,495 2008 Model Year U.S. :patriot: Base MSRP: $33,195 w/Technology Package $36,695 INVOICE 2007 Model Year U.S. :patriot: Base: $30,104 w/Technology Package $33,290 Destination = $670 2007 Model Year MSRP Canada :canada: Base MSRP: $41,000 w/Technology Package: $45,000 INVOICE 2007 Model Year Canada :canada: Base: $37,720 w/Technology Package $41,400 Freight & PDI = $1,775 (Edited May 8, 2007) 2008 Model Year MSRP Canada :canada: Base $ 41,400 Tech $ 45,100 INVOICE 2008 Model Year Canada :canada: Base $ 38,088 Tech $ 41,492 Freight/PDI : $ 1,775 Federal Air conditioning tax; $ 100 PowerTrain Engine - DOHC i-VTEC Turbo I-4 Displacement - 2300cc (2.3-liter) Compression ratio - 8.8:1 HorsepowerSAE net @ rpm - 240 @ 6000 Torque SAE net @ rpm (lbs.-ft.) - 260 @ 4500 Transmission - 5-speed automatic EPA estimated mileage City/Highway - 19/24* Emissions certification (CARB/EPA) - LEV II ULEV/Tier-2 Bin-5 Fuel type - Premium unleaded Transmission Specs Transmission 5-speed automatic with F1(R)-style Sequential SportShift paddle shifters and Grade Logic Control Ratios (:1) 1st 2.697 . 2nd 1.606 . 3rd 1.071 . 4th 0.766 . 5th 0.612 . Reverse 1.889 . Final 4.533 Chassis Body Type - All-steel unit body Front Suspension - MacPherson Strut Rear Suspension - Independent multi-link Shock Absorbers - Front and Rear Twin Tubes Stabilizer Bars Front - 21 mm diameter Rear - 19 mm diameter Steering Type - Torque-sensing variable power-assisted, rack-and-pinion Steering Ratio - 15.1:1 Steering Wheel Turns (lock to lock) - 2.76 Turning Circle (curb to curb) - 37.4 ft Wheels 18 X 7.5 JJ cast alloy wheels Tires - P235/55R18 99V high performance all-season Braking System - 4-wheel Anti-lock Braking System (ABS) with Electronic Brake Distribution (EBD) and Brake Assist Front Discs - 11.7 inch (297 mm) diameter ventilated (w/ dual piston caliper) Rear Discs - 12.0-inch (341 mm) diameter drum in disc Stability Control - Vehicle Stability Assist (VSA) with Traction Control System (TCS) Exterior Demensions Interior Demensions Front Weights Curb Weight - 3968 lbs (1800 kg) W/ Technology Pacage - 3982 lbs (1800 kg) Weight Distribution (% front/rear) 52/48 Fuel Economy EPA Fuel Mileage - City/Highway - 19/24* mpg (City/Highway) *Preliminary mileage estimates determined by Acura. Final EPA mileage estimates were not available at the time of printing. Use for comparison purposes only. Your mileage may vary. Towing Maximum Towing Capacity - 1500 lbs Capacities Cooling System - 2.4 gallons/9.1 liters Fuel tank - 18.0 gallons/68.0 liters Volumes Total - 6.09 quarts/5.8 liters Acura recommends Mobil 1 Synthetic Penzoil Platinum Plus has also achieved the HTO-06 certification Country of Origin United States (Marysville, Ohio) Please PM me if there is anything else you would like to see added or that is missing. Road & Track Specifications with performance statistics. Road & Track Specifications |
