Notices
RDX 2007 turbo acura
Old 05-10-2019, 11:01 AM
A C
New Member
Check engine light is on .Couple codes co2 code transmission code and heat code.What should I doMy mechanic suggest to change whole turbo ,I need second opinion
A C is offline
Old 05-10-2019, 11:18 AM
FOUR RINGS
1killercls's Avatar
Received 1,572 Likes on 1,031 Posts
AC ..You know there is a whole section devoted to your car on this forum. I know, crazy huh!
1killercls is offline
Old 05-10-2019, 11:21 AM
ttribe's Avatar
Received 4,514 Likes on 2,435 Posts
MODERATOR NOTE: Thread moved to model specific forum.
ttribe is offline
Old 05-10-2019, 11:42 AM
Registered Member
Get a list of the actual codes car is throwing, describe in as much detail any other symptoms you're experiencing, and the folks here can do their best to give you that 2nd opinion.
Tomtwtwtw is offline
Old 05-10-2019, 08:32 PM
Carmine S.
CSmoney28's Avatar
Go to auto-zone, get pictures of the codes it’s throwing they’ll read them for free, and post the pictures up.
CSmoney28 is offline
Old 05-10-2019, 11:03 PM
Registered Member
whats the code? is it p2263?
kevin2m4 is online now
Old 05-10-2019, 11:10 PM
Registered Member
mechanics call turbos a lot for the turbo code, which may be caused by slack in the waste-gate actuator, not knowing it is replaceable, or even adjustable. ive seen the code go away from just moving the nut on the arm a few turns until the slack is out.
Old 05-15-2019, 11:12 PM
New Member
Your mechanic is an idiot !
Do you have any transmission slipping? Besides the check engine light being on? If you have slipping, flush out the transmission fluid, and refill. There is a refill bolt to remove and refill. Do not refill it from the dipstick. Or it will take you an hour. Replace the 3 transmission pressure switches. Then disconnect the negative side of the battery for 5 minutes. This will clear all the old codes. The car should be fine then. I would disconnect the negative battery terminal first. After 5 min, put it back on, start and drive. If no light comes back, it was an old code. Of it comes back on and you have trans slipping, follow the directions above. Make sure you only use Acura trans fluid. From the dealer. Acura are very sensitive to other trans fluids.
Dtheod is offline
04S2KGPW
New Member Introductions
03-12-2019 01:37 PM
Wanax
Third Generation RDX (2019+)
03-01-2019 12:53 PM
Quick Reply: RDX 2007 turbo acura
