Oil in my radiator
Hello all, my 07 RDX has oil in the radiator, compression test is ok and no water in engine oil or transmission and I know the turbo uses both oil and water for lube and cooling but I don't know how the two can mix. It has 180,000 miles but I don't know any service history , only had it 2 months. Thanks for any help . |
Oil in coolant
keep us posted on what you find. i was hoping for your sake it is ATF fluid in the coolant ( as the ATF has a cooler that runs through the radiator), but if it is oil from the motor then you have a really bad issue. maybe head gasket ? Turbo ? Or worse a crack somewhere in the engine |
My first thought was the head gasket but a pressure test held 15 pounds for at least 3 hours. |
And it has a new radiator |
Did you do a dye test in the radiator and check for a bad head gasket? Worst case you have to check for a cracked head. |
I'd also be willing to bet on internal radiator failure, even if it's a new rad. Could have been defective from the get go. Maybe try pulling the tranny dipstick or draining a bit of fluid to see if there's any evidence of contamination there as well? Same with motor oil.
+1 on being ATF instead of oil. Internal radiator failure is not uncommon, i take it the 'new radiator' was from the previous owner? I'd just go and get a DENSO replacemenet and flush the transmission and put in new Honda Type II coolant
I haven't done a dye test and there is no sign of water in the oil or trans fluid and the radiator is a Denso but , yes it could be leaking. I keep looking ,thanks all |
No problem I hope it works out for you, keep us all updated please. |
Now I have water leaking from somewhere above the turbo , I need to find that first since that makes the car undrivable. Hints? |
Do you have any pictures or videos of this new leak? |
Found the leak, some hoses near the turbo, had to pull the intercooler and the air box ,also a good time to inspect the wastegate maybe correct the pesky 2263 code. Found some suspicious vacuum lines too. |
