Highway Robbery - $220 + tax for a B1 service
Old 12-24-2010, 11:56 AM
ikkoku's Avatar
Just went to the stealer for a B1 service and they wanted $220 + tax. I refused and just got a lube and tire rotation. Still got raped at $150 but feel a little better than 220.
Got home and made myself feel a little better by replacing the cabin air filter myself.
time to look for another dealer or independent for next year. will try to DIY oil change in the spring.
Old 12-25-2010, 10:24 AM
russianDude's Avatar
next time bring 5qt Mobil1 jug from Walmart for $20, and you will only $70 ($20 for oil change and $40 tire rotation and balance)
Old 01-04-2011, 12:51 PM
Trolling Canuckistan
black label's Avatar
I do the same thing at McDonalds. I order a hamburger and bring my own cheese. I only pay .04 for the slice of cheese at Walmart and McDonalds would have charged me an extra .15 for it.
Old 01-04-2011, 01:10 PM
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
You still got taken.
A "lube + tire rotation" should cost < the $70 which you "saved".
They charge "$150" for the cabin air filter replacement alone. They charged you backwards.
Darn stealerships.
Old 01-04-2011, 06:21 PM
not really comparing apples to apples here. Do what you want to avoid feeling 'uncomfortable', the reality is that service writers don't give a crap what you bring, and they still make $22 for using your oil (they jack up the price to make it profitable). They advertise $29.99 full oil change, so not sure how how much profit they make from $8 bucks worth of oil.
Old 01-05-2011, 09:37 AM
4th Gear
The Sage's Avatar
You all do your self a favor and find a good independent mechanic, you will save a ton of money. I have a 2007 RDX with almost 75k on it. I have a great independent mechanic that has always done first class work on my RDX. I've never paid more than $60 for an oil (synthetic) and filter change. And he usually does the tire rotation free.
Another tip is to get yourself a K&N life time guaranty air filter and install it yourself. The same with a K&N cabin filter.
Like it or not the Acura is basically a Honda. Most reputable independent auto shops are qualified to work on your Acura, if they also do Honda. Check out online reviews when selecting the shop.
Also no matter where you have the oil changed, make sure they are using synthetic oil. I ended up with a $1000 repair to replace a valve timing part that required breaking done the engine. The part failed due to poor quality oil, my mechanic suspected my RDX was given non-synthtic oil on oil changes prior to the part failing. My independent shop did this repair and the RDX runs better than new after the repair.
If you are in the So Cal area I can highly recommend Leo & Son Garage in Bellflower.
Old 01-05-2011, 02:19 PM
VietNinjaJ30A1's Avatar
Interesting...I didn't know K&N made cabin filters. I'll have to look into this...
Old 01-05-2011, 09:00 PM
jchan2's Avatar
I'm pretty sure dealers that do the $29.99 ($24.90 in the case of my local Acura dealer) oil change special only break even and/or even lose money on the oil change itself in the hopes that once you get there, you can be talked into an air filter or a cabin air filter or a transmission flush where there is more $$$.
For a while when the Infiniti dealer was struggling for business, they did a $19.99 oil change special with coupon. My mom and I did that one time; we even got a loaner and didn't get charged the usual $5 gas allowance.
Old 01-05-2011, 09:26 PM
I am so upset that dealer is losing money over oil change that I going to cry
Old 01-06-2011, 02:14 PM
pickler's Avatar
only 200? i paid 400 dollars here and for whaT? they said my tires had perfectly even wear, brakes are still like new, all the fluids were good and still paid. I was like wait a sec so i paid 400$ so u could tell me my car is fine and rotate a few tires around WTF?! they refused a refund and i didnt wanna argue. im never paying for maintainance again. just reset the warning and change the fluids/filters.
Mike734
12-10-2021 01:25 PM
08KBP_VA
10-22-2019 01:55 PM
thegipper
09-28-2015 01:01 PM
jmaxima03
09-27-2015 10:22 AM
Quick Reply: Highway Robbery - $220 + tax for a B1 service
