Headrest Wobble
Old 01-24-2018, 12:10 PM
Sanders's Avatar
Headrest Wobble
Hi Everyone,
I’ve been noticing some small imperfections with my RDX since purchasing it last weekend. One of those is that the driver’s side headrest feels “loose” in it’s socket. Since the RDX has active headrests (doesn’t it?) I’m wondering if there’s an issue with one of the components. A diagram of the seat is attached. Does anyone know what part(s) need to be replaced? The passenger side headrest doesn’t wobble nearly as much if at all.
As a side note, I have a few other issues I want to post about. Should I include those all in one post or make separate posts for each issue?
Old 01-24-2018, 12:27 PM
Received 16,260 Likes on 11,971 Posts
swap the passenger side to the drivers side and see if it wobbles.
if passenger headrest wobbles in drivers slot, then #5 and #6 are the culprit
Old 01-24-2018, 12:51 PM
mrgold35
mrgold35's Avatar
Received 1,508 Likes on 1,176 Posts
The passenger and driver active head restraints are a mechanical system. As your lower half of the torso moves back in the seat from a sudden rear end collision an interior tray mounted inside causes the headrest moves forward like a level or seesaw to reduce the distance of how far your head/neck snaps back (hopefully) before hitting the headrest to reduce whiplash. You might have Acura check it out if replacing of parts #5 or #6 don't work.
Old 01-26-2018, 11:09 AM
CSmoney28
CSmoney28's Avatar
Talking
I have this same problem on my truck but I thought it was suppose to be like that ha-ha.
05 TLNBP
01-02-2005 09:52 PM
GOTHAM818
08-06-2003 09:36 AM
VeiLsTyleZ
01-23-2003 08:48 AM
Davidas
10-03-2002 08:48 PM
jen84
01-17-2002 05:36 PM
Quick Reply: Headrest Wobble
