Code A12
How does one Reset from coming on please? thank you
Assume you're talking about the maintenance minder code? Turn key to on position (don't start it), use buttons to navigate to the screen that shows oil life%. Hold the select/reset button for 10 seconds or so, and it should pop up with a prompt to reset. Select yes and hold for another 10 seconds or so until the car confirms the reset.
I hope you actually performed the necessary maintenance. This reset procedure is also in the owner's manual.
