Boost issue after intake installed.
Old 03-20-2015, 01:23 PM
justinxecushyn's Avatar
Recently installed an after market intake. After installing, i'm no longer hitting full boost. Checked connections to make sure there weren't any boost leaks. Boost will only to to halfway mark on the "boost gauge". Only happened after intake was installed. Seems luggish too.
Purchased intake from ebay and added an extra piece to get further into fender.
Old 03-21-2015, 04:50 AM
NBPaspec's Avatar
if the MAF housing is a different diameter than stock it will screw up the airflow reading in the ECU. This needs to be tuned with flashpro.
Old 03-21-2015, 11:49 AM
FLETCH
TheWrench116's Avatar
the maf housing is wrong size. cheap parts don't work. sell it and put the stock back on.
Old 03-23-2015, 09:01 AM
Jdrum1's Avatar
Agreed.
This isn't a '93 civic; why put cheap generic parts on a fairly complex, high performing engine?
Get the right thing (CPE or K&N), or don't bother.
Old 03-23-2015, 11:48 AM
pickler's Avatar
don't waste your money with intakes. even with MAF scaling on flashpro you will still suffer from inaccurate reading and spikes in MAF. use money for intake on downpipe or exhaust where you will get real gains.
Old 03-23-2015, 01:41 PM
FLETCH
this from a guy who drives a Subaru...which are notoriously finicky about intakes due to the design of the intake piping. I think I said something about this in another thread.
Old 03-23-2015, 01:57 PM
I'm also a subaru, issue isn't with the intake. Removed and put the stock one back on. Issue is still there.
Only 2 items were done during this time, starter replacement and intake installation. I'm thinking there may be a loose hose some where.
Old 03-28-2015, 02:22 PM
mooky's Avatar
Did you figure out what was wrong?
Old 04-04-2015, 09:20 PM
No not yet. swapped on the stock and still the same issue.
Old 04-05-2015, 08:20 AM
RDX faN BoY
rdxchris710's Avatar
Reset the ecu by pulling the negative cable. Just swapping back to stock won't do it. The maf / ecu needs to relearn.
Old 04-08-2015, 08:58 AM
That was the first thing I did after installing both aftermarket and stock.
02-25-2020 09:57 AM
cycdaniel
12-17-2019 10:58 AM
hues10
1G RDX (2007-2012)
09-07-2016 03:47 PM
09-14-2015 10:48 AM
Billu99tl
09-13-2015 11:30 AM
Quick Reply: Boost issue after intake installed.
