2011 RDX AWD tongue weight rating: how to increase?
Old 01-18-2016, 08:08 PM
kosulin's Avatar
Hi everybody.
I own Acura RDX 2011 AWD. As everybody here knows, its tow capacity of 1500 lb means 150 lb tongue weight.
Here is my problem: I need to use a hitch cargo rack which would weight 220-240 lb fully loaded. Roof rack, trunk, and trailer are not an option for various reasons.
Load distribution is not a problem as rear sits and trunk will carry very low load. My hitch receiver is rated for 4000 lb. My main concern is that frame rails may bend. Is there any way to increase their twisting/bending resistance?
Old 01-22-2016, 07:42 PM
FLETCH
TheWrench116's Avatar
take it to a chassis shop or roll cages and see if they would reinforce the area for you.
kosulin (01-23-2016)
Old 01-23-2016, 08:39 AM
kosulin's Avatar
Thanks for response.
According to GMC web site, tongue weight up to 15% is OK:
Towing Capacity: The Maximum Weight That You Can Pull Safely | GMC
Tongue Weight and Its Role in Safe Trailering and Towing | GMC
That means RDX should handle up to 225 lb fine. Will go to body shop anyway just to see what they say.
Old 01-23-2016, 01:36 PM
RDX10's Avatar
Just be careful with this. God forbid you get into an accident, regardless of how, insurance can try and use the over-loaded hitch as an excuse. It has happened in the past.
Old 01-23-2016, 01:50 PM
01acls's Avatar
The problem is not the weight as in breaking the frame with the tongue weight rating. The real concern is the front wheels coming of the ground (wheelies) and no steering control or lack of steering control from a light front end.
Old 01-23-2016, 03:58 PM
kosulin's Avatar
I will definitely test how it behaves, but do not think this will be an issue. My trunk and rear seats will carry very low load.
Old 01-24-2018, 02:08 AM
6th Gear
Lennon Giesbrecht's Avatar
Hi everybody.
Wondering if you ever got to the bottom of this or if you just drove with it as is? I have a motorcycle hitch mount and my bike weighs 200lbs and not sure if I should risk it!
Old 01-24-2018, 10:06 PM
kosulin's Avatar
I drove as it is with no issues so far. But your motorbike is 200 lbs, add to this the hitch rack weight, it may exceed 300 lbs easily. If I was you, I'd go with motorcycle trailer. Much more expensive, but you motorbike is also not cheap, I guess. And you might find a good deal on eBay or craigslist.
losiglow
19
04-30-2018 09:53 AM
RDXandPuppyLover
2G RDX Problems & Fixes
01-15-2018 02:43 PM
Philisophe
3G RLX (2013+)
18
01-14-2018 08:42 AM
Mwkaraffa
1G RDX (2007-2012)
12-05-2017 09:30 PM
Quick Reply: 2011 RDX AWD tongue weight rating: how to increase?
