2010 Rdx radio
Hello,
my radio not accepting my code? I have serial number from my radio and the code from an Acura dealership here in Ottawa. The problem I’m having is the radio is not accepting my code. What I’ve done so far is disconnected negative on battery also pulled out 20amp and 7.5amp fuses. Pulled out radio and disconnected and reconnected cables in the back. Any suggestions would be greatly appreciated. |
Make sure the code is for the radio and your not mixing it up with the code for the navigation. The navigation you use the top dial also the radio you use the cd 💿 disc numbers.
Rdx radio
Thanks for the input
however I do not have a Nav system in my vehicle and also the CD player does not have any numbers on it . Back to square one for me any other suggestions? thanks again |
Oh I have the tech I guess my set up is different sorry
