2008 RDX Replacement headlamps
Old 07-31-2018, 09:42 PM
5th Gear
Robert Topper's Avatar
I've been digging through all the posts assuming this was a popular issue, but I can't seem to find anything. So, basically, I have redone my headlights once already,but they're needing another renewal. I spent $400 on both HID headlamps for my Mercedes. I can't find the Acura headlamps for less than $400 a piece. Why are they so sparse? Why are they so expensive? I guess I can hit the scrap yards and see what I can see. Anyone else have any luck?
Old 07-31-2018, 10:42 PM
schen72's Avatar
What do you by "redone" your headlights? Do you mean getting them de-hazed? Or replacing the assembly entirely?
Old 08-01-2018, 05:14 AM
5th Gear
I de-hazed them initially a few years back. I didn't use a kit, I used several levels of sand paper, and then sprayed a new clear coat. Now, instead of doing it again, I'd like to just replace (if I can find some at a decent price).
Old 08-01-2018, 07:13 AM
Received 16,260 Likes on 11,971 Posts
perhaps an aftermarket headlight would be cheaper? a DEPO version would be cheaper than the OEM version.
try checking out ebay for used parts....
or you can even check out Car-Part.com--Used Auto Parts Market to scour local junk yards for the headlight.
Old 08-01-2018, 07:53 AM
5th Gear
I've been scouring through the web for some. Ebay has a right assembly for $300+ and a left assembly for $400+. and I don't even know if they match completely. Oh, and that's the used price. I'll check out the Car-part.com I haven't seen that one. and I saw a for sale section on this site that I haven't looked through.
Thanks all.
Old 08-01-2018, 08:07 AM
i mean, it is a 10 year old vehicle that is rarely seen on the road any more... used parts will only be harder to come by.
Old 08-01-2018, 09:58 AM
mrgold35
mrgold35's Avatar
Received 1,508 Likes on 1,176 Posts
I purchased my 08 RDX back in 2010. I live in the southwest with plenty of clear skies and UV damage on every headlight after a few years. I did 3M clear bra at the time of purchase on the front end, side mirrors, and headlights. The clear bra has a UV filter and my headlights are still clear after +8 years with the film. It might be cheaper to polish the HIDs again; but, add a film with UV protection afterwards. I also upgraded my HIDs to Osram Xenarc 66240CBI HIDs bulbs and they are a big improvement over the OEM bulbs. You can do the polish, UV film, and upgrade the HIDs for under $200 compared to +$700 purchasing used on eBay.
Same 3M film on my 06 TSX for +12 years and 11 MDX +4 years with zero UV hazing of HID covers.
Old 08-01-2018, 10:09 AM
5th Gear
Looks like that is going to be my best best. Thanks for the data on the bulbs and 3M film. I think I'll go that route.
Old 08-01-2018, 06:44 PM
schen72's Avatar
I did something similar. I never had to dehaze them, but a few years into owning the car, I had "paint protection" film added to the headlights for about $130. The car is now 10+ years old and the headlights look brand new. It is parked outside all the time.
Old 08-03-2018, 11:14 AM
wusty23jd's Avatar
+1 for the 3M clear bra. I added this protection to my TL once I finished detailing/polishing my lenses. I will be doing the same to my wife's RDX when I detail her car in a few months.
Old 08-07-2018, 04:26 PM
OhRDX's Avatar
I may have an extra set of headlamps in the garage, I’ll look for them later this week if you or anyone is looking for some.
Old 08-07-2018, 07:52 PM
5th Gear
Depending on the condition and price, I might be. Go ahead and post some pics when you dig them up.
Old 09-10-2018, 05:08 PM
Denvermgb's Avatar
I've done the sand/polish/coat to headlamps on my Leus RX, worked great and lasted a long time. Going to do the same treatment to the '08 RDX I just bought. I think it's the best way to go and more in-line with my budget.
Denvermgb
Old 09-10-2018, 07:15 PM
CSmoney28
CSmoney28's Avatar
Does anyone have diy instruction for the headlight restoration and a list of necassary tools?
Old 09-10-2018, 08:23 PM
Tomtwtwtw's Avatar
Get a highly-rated kit off Amazon and follow the instructions. A drill for buffing is all you should need, and some kits don't even require that (but it definitely helps). Also some painter's tape to protect the hood and bumper. It's quite easy if you just take your time with each step. If you try to rush through, you're bound to leave some cloudy spots behind - much like shaving too fast.
Old 09-10-2018, 08:27 PM
CSmoney28
CSmoney28's Avatar
Thanks, I appreciate the advice!
Old 09-11-2018, 10:56 AM
mrgold35
mrgold35's Avatar
Sometime, headlight can haze over faster the next time once you polish them. I think there is some protective coating that might get polished off when you restore them? I would check into some type of protective film with UV blocker after the restore.
Old 09-11-2018, 11:17 AM
wusty23jd's Avatar
Correct, the headlight restoration process will remove the OEM protective UV coating. You should definitely put some form of protective coating on them after you restore the lenses (either spray, liquid application, or clear vinyl bra).
I recently wrote a thread about a set of 3g Acura TL headlights that I modified and documented my lengthy journey with restoring the Honda plastic lenses:
https://acurazine.com/forums/third-g...l-eyes-972240/
Regarding the headlight restoration process, please refer to my comments in Steps II, XI and XII.
Keep in mind that there is a difference between a moderate restoration and a full restoration. Sunlight will tell you if you've restored your lenses correctly.
Old 09-11-2018, 11:58 AM
CSmoney28
CSmoney28's Avatar
Cool thanks, I’ll do anything 3m their the best in my opinion.
Old 09-11-2018, 12:01 PM
Tomtwtwtw's Avatar
Forgot to mention the coating - definitely worth looking into. After my first treatment, it took about 2 years in the AZ sun to start looking faded again (although not nearly as bad as before my first fix). But, my car also doesn't get much sun. Someone without a garage or covered parking at home and/or work would likely see it fade much sooner.
Old 09-11-2018, 12:40 PM
wusty23jd's Avatar
3M is a great company and I do love their products for pretty much everything. However, I can guarantee that your headlights will contain swirls if you don't finish it up with Megs 105 or a similar compound. It's not a 3M problem. it's a problem with the soft plastics. Just keep this in mind
Good luck
Old 09-13-2018, 12:21 AM
CSmoney28
CSmoney28's Avatar
Thanks I really appreciate all of the advice. I will try to use both products. As I park in the driveway at home but I’m the street at work, I’m always in direct sunlight.
Old 09-22-2018, 07:36 AM
Dhammond823's Avatar
2008 Acura RDX headlamp
I have been searching as well. We just purchased a Silver 08 RDX. The drivers side light is perfect and has a silver interior, the passenger has moisture in it and the interior plastic is black. I was curious if you were able to find an extra set in the garage? If so, what color is the interior, and would you want to part with them?
Quick Reply: 2008 RDX Replacement headlamps
