Washer Fluid leak
Old 12-30-2018, 04:39 PM
russianDude's Avatar
Washer Fluid leak
Seems like exact symptom as this tsb. Should I try asking for goodwill as TSB suggests? Seems like dealer can do it cheap and quickly ($15 parts).
https://honda.oemdtc.com/TSB/B08-023.pdf
Old 12-30-2018, 05:22 PM
Not sure if its necessary remove fender to re-adjust the bolts. Seems like the neck can be replaced by itself without removing the fender. that maybe good enough?
Old 01-03-2019, 10:43 AM
2006 NBP TL MT6/ 02TL-S
AlanW's Avatar
Mine was leaking badly. It was a broken plastic part right at the pump where it divides the flow into the 2 little hoses for each side. I had to take the bumper off to get at it. I fixed it with some sealant/glue stuff, let it dry for awhile, and it has been good since.
Old 01-03-2019, 11:40 AM
my problem is different. Its exactly what tsb say, only leaks at the neck where it connects with reservoir. After level drops bellow neck it stops leaking.
seems like there is a defect in original part and Acura has updated part for the neck.
Old 01-03-2019, 01:49 PM
Received 8,582 Likes on 6,629 Posts
If there's a TSB, just take it in
Old 01-03-2019, 02:12 PM
yeah, surprisingly tsb says that service manager may consider it for good will.
Old 01-05-2019, 06:34 PM
CSmoney28
CSmoney28's Avatar
Happened to me, I had to get a new tank...
Old 01-05-2019, 06:53 PM
Why new tank, the TSB says to replace the neck? Is this a different issue?
Old 01-05-2019, 08:08 PM
CSmoney28
CSmoney28's Avatar
My tank ended up being cracked...
BartmanEH
20
12-17-2019 07:37 AM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
jakevogel
1/2G MDX (2001-2013)
12-16-2013 09:17 AM
vtec1jk
02-21-2007 07:53 PM
Quick Reply: Washer Fluid leak
