Notices
200,000 miles! I did it!!!!!!!
Old 06-27-2019, 06:54 AM
  #161
rockstar143's Avatar
Received 15,085 Likes on 11,230 Posts
So what are you asking us for? you aren't planning to figure it out or do anything about it on your own
then why waste our time? I guess let us know what they find.
rockstar143 is online now
Old 06-27-2019, 01:47 PM
  #162
WTF?
Midnight Mystery's Avatar
The purpose of this thread is to document what I'm going through with the vehicle.
If anything goes wrong, I post about it here pretty much immediately.
As of now, all is working like normal...
I'm trying to gather ideas because no one knows how to work on this thing... Even the dealer messes up occasionally..
If I can get some other RDX owners that have had similar issues in here and post about it, I may be able to "get closer" to solving the problem so that I can help guide it to a proper repair.
Like the window actuators... I knew that was the problem, yet the dealer was all like, "It's thw motor and regulator"...
Many other RDX owners have reported window actuator issues and this is how I can pretty much confirm my suspensions...
Midnight Mystery is offline
Old 06-27-2019, 01:48 PM
  #163
WTF?
I'll tell the dealer to check the main grounds...
J, didn't this happen to your TL-S?
Old 06-27-2019, 01:59 PM
  #164
but what's the point, you're not a mechanic. Let the mechanics figure it out.
This isn't documenting, this is you having an issue and asking a question
You just stated you would do nothing with the responses.
Yes, my TL-S had a ground issue due to previous owner replacing the oem ground with speaker
grade wiring.
Old 06-27-2019, 02:13 PM
  #165
WTF?
I think I may have found the problem...https://acurazine.com/forums/1g-rdx-...-start-680923/
I'm experiencing a CEL/Transmission light for the range sensor....
Maybe this is "along" the lines of nuetral safety switch?
It started after the tow, just like the guy in this thread I liked...
If it fails to start again, I'll push the shift interlock button or run the shifter from P-S back and forth a few times to agitate the connection and *hopefully* get it to work...
But the linked thread is my exact issue.
To do list.
1. Address Range Sensor issue.
2. Address A/C issue
3. Change engine oil
4. Get tires
Old 06-27-2019, 02:23 PM
  #166
WTF?
Range sensor is also caudimg my backup camera/reverse lighrs to come on sometimes...
Hopefully to kill two birds with one stone here!
Old 06-27-2019, 03:56 PM
  #167
WTF?
The dealer ordered a range sensor to have in stock if I need it.
Will have that and all of the following addresses next Wednesday.
Old 07-03-2019, 01:06 PM
  #168
WTF?
At the dealer now, waiting on all of the maintenance and a tire quote. I got another tore quote for Michelin Premiers for $986 out of the door, but I perfer my dealer to do it since I will also be getting an alignment there...
I also licked a pole in the back passenger corner nothing scratch out can't fix!
Old 07-03-2019, 02:37 PM
  #169
Registered Member
I keep buying Brigestone Turanza Serenity Plus for the same amount of money out of the door which last time lasted me more than 70K miles last time. excellent tire.
russianDude is offline
Old 07-03-2019, 02:47 PM
  #170
WTF?
My current Bridgestone Duhlers have lasted me about 90K miles... They were almost new when I bought the RDX with 175K miles three years ago, but I did have to replace one tire at 180K because of a nail in the inner sidewall.
They're OK, but don't really grip enough for the vehicle...
I hope to get about the same out of the Michelins... I mainly drive highway....
Old 07-03-2019, 02:54 PM
  #171
Registered Member
I would go with what you know. OEM michelines were the worst, only got 25k miles out of them.
Old 07-03-2019, 04:36 PM
  #172
WTF?
I know... I'm not getting the MXM4 or whatever that is....
The Premiers are highly rated and rate for an average life of about 60K miles.....
The A/C issue was the relay, or atleast we're 90% sure! Should be good!
Also having the O-Ring in the steering replaced "finally" to fix the humming pump I've had simce I got the RDX... Walker Acura told me it was the rack AND the pump, they're full of BS there!
I had a bad belt tensioner I didn't know about, did that too...
Also, replaced the range sensor.... Waiting on the wash now... It's dirty, taking them a while!
Also... My battery terminal IS good! It's corroded because the 100 month battery from Walker Acura from 2017 is leaking acid... They cleaned it, but I hope to have that battery replaced... The receipt faded, so we'll see how that goes...
Otherwise, all looks good!
Old 07-04-2019, 08:30 AM
  #173
4th of July sales today...
on discounttiredirect...you can get some crazy deals if you're not too lazy to use their credit card to pay (then pay off immediately after)
and turn in the rebates.
Old 07-10-2019, 11:40 PM
  #174
WTF?
Ordered the Premiers... Was supposed to be installed today... They only were delivered two by their supplier, so rescheduled for tomorrow....
But... This happened!
