Notices
08 RDX 100,000 mile service
Old 04-25-2019, 08:30 AM
New Member
I'm looking for info on what to replace and maintenance for 100,000 mile? Advice is appreciated!
08rdx12345 is offline
Old 04-25-2019, 12:24 PM
Registered Member
Do you have a detailed service history of the car so far? Yes/no to that will help determine what you should consider at 100k.
Tomtwtwtw is offline
Old 04-25-2019, 12:53 PM
Carmine S.
CSmoney28's Avatar
Engine Oil
Engine Oil Filter
Tires
Brake Pads
Rotors
Engine Air Filter
Cabin Air Filter
Rear Differential Fluid Flush
Transfer-case Fluid Flush
Transmission Fluid Flush
Fill Windshield Washer Fluid
Flush Power Steering Fluid
Flush Brake Fluid
Check all brakes and hoses.
Spark Plugs & Ignition Coils
CSmoney28 is offline
Old 04-25-2019, 01:10 PM
New Member
thanks CSmoney!
Old 04-25-2019, 01:47 PM
Registered Member
About two years ago I got mine, in Canada @208000km.
Thanks to the contributions on this site, at the time also did:
A) All three pressure switches for the automatic transmission were replaced with Acura original parts from dealership. Kept the old ones, search about "Diy transmission pressure switches replacement", thank you "https://acurazine.com/forums/members/dcmodels-271275/"
B) the water pump, auxiliary s-belt, mechanic assessed belt had not been recently changed.
C) the relay for the air conditioning circuit was also replaced, was a cheap preventive item.
D) CHECKED the valves, and only 2 required adjustment.
E) replaced the power steering tank, has a filter built-in, non removable, best time to do it before completely replacing the power steering fluid.
F) the valve cover gasket had signs of leaking-maybe, no leaking signs ever since.
I chose to add a block heater (little item to help engine start easier around here in winter, so had no problems starting up despite last year reaching a record windchill cold of -37C - coldest since 1938 when temperature recording started here).
Also, could not straighten out the fins on the original intercooler (~85% were bent, blocking the cooling airflow, I gave up after several days of back aching attempts) so happy to have had ETS cooler as replacement, your situation may be different.
Hth
Altair is online now
Old 04-25-2019, 02:54 PM
Registered Member
Maintenance minder subcode 4?
that should be spark plugs and valve adjustment
brake fluid flush is 3 year interval - there is no mm subcode for it.
everything else the car will reccomend
kevin2m4 is offline
Old 04-25-2019, 03:02 PM
Registered Member
kevin2m4 is offline
RVator
2G RDX DIY & FAQ
20
04-11-2019 05:11 PM
darkdeuce
Second Generation TL (1999-2003)
19
02-11-2011 07:35 PM
khiyal
Ramblings
09-12-2007 02:44 PM
Quick Reply: 08 RDX 100,000 mile service
