08 RDX 100,000 mile service
I'm looking for info on what to replace and maintenance for 100,000 mile? Advice is appreciated!
Do you have a detailed service history of the car so far? Yes/no to that will help determine what you should consider at 100k.
Engine Oil
Engine Oil Filter Tires Brake Pads Rotors Engine Air Filter Cabin Air Filter Rear Differential Fluid Flush Transfer-case Fluid Flush Transmission Fluid Flush Fill Windshield Washer Fluid Flush Power Steering Fluid Flush Brake Fluid Check all brakes and hoses. Spark Plugs & Ignition Coils |
thanks CSmoney!
Originally Posted by 08rdx12345
(Post 16416380)
Thanks to the contributions on this site, at the time also did: A) All three pressure switches for the automatic transmission were replaced with Acura original parts from dealership. Kept the old ones, search about "Diy – transmission pressure switches replacement", thank you "https://acurazine.com/forums/members/dcmodels-271275/" B) the water pump, auxiliary s-belt, mechanic assessed belt had not been recently changed. C) the relay for the air conditioning circuit was also replaced, was a cheap preventive item. D) CHECKED the valves, and only 2 required adjustment. E) replaced the power steering tank, has a filter built-in, non removable, best time to do it before completely replacing the power steering fluid. F) the valve cover gasket had signs of leaking-maybe, no leaking signs ever since. I chose to add a block heater (little item to help engine start easier around here in winter, so had no problems starting up despite last year reaching a record windchill cold of -37C - coldest since 1938 when temperature recording started here). Also, could not straighten out the fins on the original intercooler (~85% were bent, blocking the cooling airflow, I gave up after several days of back aching attempts) so happy to have had ETS cooler as replacement, your situation may be different. Hth |
Maintenance minder subcode 4?
that should be spark plugs and valve adjustment brake fluid flush is 3 year interval - there is no mm subcode for it. everything else the car will reccomend |
