Stock Wheel Specs
Old 01-05-2010, 04:55 AM
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,143 Likes on 4,810 Posts
Stock Wheel Specs
Hey guys, Ive searced around trying to find the specs of the wheels off a newer model NSX but I havent had any luck. Im looking for the 17" wheel specs. Id like to know the offset and the width.
And Id also like to know if a big brake kit can fit behind them. IIRC the 05 models had 11.7" rotors, so Im trying to figure out if a 12.6" rotor and 4 piston caliper will fit.
Thankyou in advance.
Old 01-05-2010, 05:01 AM
civicdrivr's Avatar
I was able to locate widths on Wheel Collision Center, but still no offsets.
If anyone can supply that info it will be greatly appreciated
Old 01-06-2010, 06:00 AM
civicdrivr's Avatar
Someone correct me if Im wrong, but the front wheels are in the 40-50mm offset range, no?
Old 08-23-2010, 11:20 PM
LA2LR's Avatar
2002 - 2005 Front 17" 7" 17.35 lbs. 2002 - 2005 Rear 17" 9" 20.0 lbs. I believe 2002-2005 front wheels are 17x7 with a 55mm offset and the rears are 17x9 with a 56 mm offset. HTH!
Old 08-24-2010, 12:52 PM
civicdrivr's Avatar
Wow thread revival. Thanks for the info!
Old 08-29-2011, 02:57 PM
5th Gear
lakestreet's Avatar
that's a pretty high offset. you wonder what sort of spec difference it would have made to have much wider tires that even "sporty" cars are running today on the NSX. like a 245/275 setup would probably have made a massive difference on all the numbers it put up.
advan031
5G TLX Photograph Gallery
11-14-2015 07:44 PM
devinv1994
09-03-2015 01:40 AM
bailey24
08-31-2015 05:38 PM
Quick Reply: Stock Wheel Specs
