Need Help With 2004 NSX Manual Transmission Fluid Change
Can someone please help verify the location of the FILL & DRAIN plugs for the manual transmission on a 2004 NSX?
Im pretty sure of the drain plug location as it has a 3/8 square insert and a crush washer.
I have located another larger bolt with a crush washer about 5 or 6" above the drain. And if this is correct, it appears this larger bolt might be a view hole for the fluid. Is this also the fill? I am wondering if anyone knows of a better fill hole on top of the transmission instead of the side?
Can someone please verify this for me with detailed description of the location? Pics would be great too!
I have searched the net like crazy with no answers.
Thanks!
Thanks!
It sounds like you have the correct locations figured out. Make sure you can get the fill plug out before draining the oil. I used a little fill pump I got from Amsoil to get the new stuff in there. You just fill until it starts running out the fill hole, then put the fill plug back in.
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
Mike Bertram
09-10-2015 09:27 AM
HeloDown
09-08-2015 06:51 PM
