Driver Height
Driver Height
I went to test drive an NSX recently & altho I fit fine (I am on the short side), my friend who is 6'2" did not fit that well: his head was up against the ceiling. We adjusted the seat as much as possible but no help - the only way was to take the top off.
So, is anyone here 6'2" or taller? If so, how do you fit in your NSX?
Thanks!
Thanks!
Received 2,328 Likes
Its all about how tall you are in the torso.
Someone who does 'fit' in an NSX at 6'3" might just have long legs
Dali sells a small cushion to accommodate taller drivers. Also if it's an older NSX, may be a good time to get some aftermarket Recaro's or Brides. The rails will sit lower then OEM which will help.
xsilverhawkx
09-28-2015 06:51 PM
4drviper
09-23-2015 07:42 PM
