Any Acura techs in the house?
Old 03-24-2010, 10:02 AM
6th Gear
Bird333's Avatar
Can someone tell me (or check with a friend who works at Acura or has the service manual) where the 'S' line/wire from the alternator on a '95-'05 NSX goes to? If someone could take a pic/scan the page from the service manual that would be even better.
Old 03-24-2010, 12:21 PM
KaMLuNg's Avatar
Received 1,090 Likes on 767 Posts
try the NSX forums...
Old 03-24-2010, 12:22 PM
One on the right for me
subinf's Avatar
Service manual is available online.
The only way I'd be able to take a picture is of it on my computer screen.
Google 'acura tl service manual' and then click on the first link. On the left side of the screen there will be a link to the NSX manual.
Old 03-24-2010, 04:34 PM
juniorbean's Avatar
Received 1,760 Likes on 1,046 Posts
, if there are any Acura techs with NSX knowledge in the house, they'd be in the NSX section. Moving this there...
Old 03-24-2010, 07:09 PM
Former Sponsor
nsxlife_acuraoflynnwood's Avatar
I'm not a tech, I Manage the Service Department at Acura of Lynnwood and I personally own an NSX. If I don't know the answer to your question(s), I have some of the BEST NSX techs in the country that work for me and I'll be able to get you the answer.
I'll do my best to identify what you're talking about. First, there is no 'S' (signal) line/wire on the alternator, that would relate to the starter. On the back of the alternator there is a green connector that goes to the main wire harness which ends up at the PCM. The other wire on top of the alternator which should have a black rubber boot is your 'B+' or Battery positive wire, which goes to the battery.
Hope that helps
Old 03-25-2010, 09:04 AM
6th Gear
Bird333's Avatar
Thanks for the reply. I have seen that manual already but it is for a '91. Are you saying that the alterator connections are exactly the same as the later models?
Old 03-25-2010, 09:08 AM
6th Gear
Bird333's Avatar
Hope that helps
On the green connector there are four wires. On a parts website they are labelled 'FR', 'IG', 'L' and 'S'. I am wanting to know where the 'S' line goes to?
Old 04-19-2010, 09:27 PM
sy272004's Avatar
dont want to start new thread, how hard is it to take wing off 2005 nsx? is it just 4 bolts on inside of the trunk? is it on double sided tape as well or just foam strip around edges?
Evil Teo
3G MDX (2014-2020)
14
08-16-2020 04:29 AM
ssjkev16
03-08-2020 08:17 PM
02-25-2020 09:57 AM
iRaw
ILX
09-05-2015 12:10 AM
Quick Reply: Any Acura techs in the house?
