shifter bushings
4x4- fat chicks cant jump
shifter bushings
over in the 3g tl forums, theyve found some aluminum bushings for shift cable ends and they're supposed to make shifts more precise for $30. it looks like the part numbers for 3g tls and 1g cl 5mt match up on acuraautomotiveparts.org. here is the thread: https://acurazine.com/forums/showthr...9&page=1&pp=25
someone should try these out, id like to get them eventually. just thought id let you know, and someone may want to double check the part numbers to make sure that im correct
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
How bout YOU try for $30 and let everyone else on the forum know
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by 5-speed
i probably will, but i was letting everyone else know about them.
(Mid-Atlantic)
(Mid-Atlantic)
nah its all good.
Ciao Pho Eva eva
"Cool, if you buy a pair ill take them back and credit you if they dont fit (regardless of condition of what you return)
Tai
CorSPort"
So i will try the install, take pics, and review..
Ciao Pho Eva eva
OK 6 months later, and i installed the shifter bushings from corport. Problem now is, i dont know if the company is still a AZine vendor.
BUt it took 15 mins to install and it made the gear box feel a LOT crisper.
aluminum > rubber
aluminum > rubber
Ciao Pho Eva eva
Originally Posted by acuratl_2nr
are theses just two bushings that replace the ones where the shifter cable attatches to the shifter or is their more involved to the install??
all i did was take the stock bushings off, replace them and put a new pin-wire thing and 2 E-clips back in. soo simple
Ciao Pho Eva eva
Ok so this is a picture of the area under my intake.. u cant miss it..
THe corsport kit includes 2 bushings, u will need to grease the 'shaft part' and installation is easy.
Originally Posted by Palayah8ta
did u get ahold of corsport?
cool.. just remember to grease the inside of the bushing.. it says that on the instructions, but i forgot and paid for it.
Ciao Pho Eva eva
Originally Posted by gotguinness?
Just placed my order...Where do i get the grease? what type of grease am i looking for? Thanks.
The cable is located under the stock airbox?
I'm actually thinking of using these shifter bushings in conjunction with the P-Spec short shifter kit...what do you guys think? Will there be problems/disadvantages or will it be pointless using the shifter bushings with a short shifter? Has anyone done this yet? Any info or advice would be great. Thanks!
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by saiko_cl_duck
when is it NOT good to replace bushings? I would imagine it's only going to help.
