seafoam
seafoam
I've got my dear primrose '97 acura 2.2 CL and I've Seafoamed the gas tank. The car wasn't noisy to begin with but now it's almost silent when running. I noticed on the can it talks about putting Seafoam in the engine and other areas. What I would like to know is whether you folk only Seafoam the gas tank or do you actually put it in the engine or elsewhere?
thanks
thanks
Actually just pouring something into the gas tank can be amazing. I used something, can't remember what, in my 85 Mustang prior to going thru my emissions test and passed. Even my mechanic who did the test was amazed I passed.
Originally Posted by tman89544
Someone should really do a DIY on this, i would do it if i knew exactly what to put it in.
there is one in the "Diy" section just search, its not that hard either to seafoam engine
666 Speed
1 Post
-1/3 into the oil and let it run. Car will sputter and want to die but keep it alive but not above 2500-3000 rpm. Once its run for a bit (like 10-15 min) change your oil with a fresh filter making sure that you drain as much of the old oil as possible. Would be a good thing to let it sit and slowly drain for a while.
-1/3 through a vacuum line into the intake or through the throttle body if you have a V6 (the breather hose from the valve cover works well. Just make sure that the intake is tilted upward so the seafoam flows into the engine). When you have a bit left, make the car suck it up quick and let it die. If it doesnt, shut it off quick. Then let it sit for 15 minutes minimum. When you try to restart it, it wont want to start but keep cranking with the gas pedal down 1/4-1/2 way and it will eventually start. This is where the fun begins. Rev it up and watch the white smoke come out of your exhaust pipe
-1/3 in the gas tank after everything above.
666 Speed
1 Post
Another way to do it:
http://youtube.com/watch?v=dQ1wpO6Oj8E
Oh the smoke fun:
http://youtube.com/watch?v=sCQpwEcynkk
http://youtube.com/watch?v=x6P461X3dtc
http://youtube.com/watch?v=EJH01j6MXec
http://youtube.com/watch?v=a0RmnT05QmM
Everyone says to do it this way for a V6:
http://youtube.com/watch?v=t3hFSrcieTY&feature=related
But I think that its not useful as it only hits 3 pistons
Oh the smoke fun:
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
acuratl26
04-23-2020 07:30 PM
EPS CL
06-02-2009 11:16 PM
manteuffel
03-12-2006 11:12 PM
