Question and Answer Thread
Old 03-18-2010, 11:26 PM
  #561
Land of Pleasant Living
shnee's Avatar
scratch that...
16x7 45mm
What's the biggest tire I could put on that without rubbing?
Old 03-18-2010, 11:57 PM
  #562
shnee's Avatar
screw it
Old 03-20-2010, 12:21 AM
  #563
Myxomatosis's Avatar
Well I don't have a question. ok can two swallows carry a coconut in tandem by a string?
African Swallows of course.
So I did my sway bar end links last week. Amazingly easy, took an hour and a half to do both sides. Car does handling much firmer, tighter.. Not bad for $15.
Now ball joints, saved the worst for last.
I do have a question then, any tips on doing those?
Old 03-20-2010, 08:12 AM
  #564
First EVER K24 Turbo CL
starboy2nv's Avatar
Originally Posted by f22vtec
hey does anyone on here have an amber bulb/led bulb in their amber corner in the headlight? Do you guys think it wud be too much with an amber corner bulb and corner tinted amber? or just go with a white led corner bulb behind the amber corner lolll
i do.. looks hot on a black cl... dunno bout any other color...
i say no to led.
Old 03-24-2010, 01:40 PM
  #565
unlewser's Avatar
Question: Does a 3.0 catalytic converter fit on a 2.3? I'm guessing it should, but would like more afirmation
Old 03-24-2010, 01:59 PM
  #566
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,408 Likes on 3,020 Posts
The piping is larger on the 3.0 cat, therefore the flanges may not bolt up correctly
Old 03-27-2010, 01:00 AM
  #567
CL in lawnmower status
mitch14's Avatar
18x8 +38 front
18x9 +38 rear
any input guys? just trying get an idea of how these are gonna line up with the fenders and all, i think i have a pretty good idea, but i haven't test fitted much on the cl
also other important info, slammed on ksports, no camber kit about -2 to -3 degrees of camber all around, probably willing to cut a little bit of rear fender if needed
i guess at this point i just don't know how everything is going to line up, as i haven't had the chance to put anything wider on stock to drive on, and check things, just done simple mock-ups with the car in the air and all
and the kind of wheels....something JDM...no other hints
Old 03-27-2010, 01:14 PM
  #568
i like acura
spencer_homer's Avatar
it fit no problem. your gonna want a mild stretch for clearance, but should be fine.
Old 03-27-2010, 03:24 PM
  #569
mitch14's Avatar
^fender clearance or inner (suspension component) clearance? or both?
and by mild stretch, you mean 225's on the 9" wide? and probably 215 on the 8"?
just wanna get a rough idea, gonna paypal money soon
i was hoping to run 235's on the 9 wide, but i dunno if it's gonna be possible, i might just wait till i get them too...but that might be a while
i did test fit some wisers on the rear, 8.5" wide with 235's and i really liked the way they looked, not stretched at all really
Old 03-31-2010, 09:44 AM
  #570
South Jersey CL's Avatar
one of my HIDs isnt lighting up. it went out last night, then it came back on, and it didnt light up this morning. there was no pink or anything, and the ballast isnt making the high-pitched hum, so im guessing its the ballast? or is it something else? i checked all the connections
Old 03-31-2010, 11:13 AM
  #571
shnee's Avatar
What kind of HID setup are you using?
If all the connections are secure, and your ballast isn't humming as it normally does, I'd say yes, your ballast is dead.
If you swap the bulbs and both light up on the other side, the you know the bulbs are fine.
If you swap the ballasts and the problem follows one ballast, you know it's probably not a connection issue.
Old 03-31-2010, 11:19 AM
  #572
its the 6000k kit from HIDextra. and i swapped the ballasts and the the ballast is definitely dead cuz both bulbs lit up.
Old 03-31-2010, 11:28 AM
  #573
(Mid-Atlantic)
Sound like the ballast for sure
Old 03-31-2010, 08:47 PM
  #574
salogCL's Avatar
question regarding front/rear 3.0 rotors. i upgraded mine, the used ones are still in decent shape alot of material left, no warping. i was wondering if any hondas can use these rotors
that way i can sell them to a larger group, no many CL's around in toronto
Old 04-02-2010, 06:38 PM
  #575
shnee's Avatar
Prelude lower ball joint replacement:
http://www.jdmpowerhouse.com/diyballjoints.html
Looking at this and looking at my car, it seems like it should translate pretty easily. I like this guide as opposed to either manual I have, because with this method, I don't have to bother with separating the hub unit or removing the knuckle or any of that crap.
Does anyone see anything I'm missing that will make this too different to work?
Also, how does one remove the wheel bearing cover? It looks like it could just pop out, but I have no experience with it.
I have a few things to do and I'd like to get everything knocked out at once, and I'm hoping that can be tomorrow. So any insight would be appreciated asap!
Old 04-04-2010, 03:40 PM
  #576
well, I pulled a stupid, I've still yet to fix my sqeaks in my from drivers side suspension. Changed the sway bar links, changed the axels, and last night I decided to change the strut. However Acura must have torqued down the fork bolt to the point that it would not come off.
So like an idiot I cut it off and then realized it's a splined bolt. I really hope my acura or honda dealer has it. My cars up on a block and I'm driving wifey's car. Plan now is to check with them and if they don't have it, I'll buy a 9.8 rated bolt for the the time being at home depot.
Not really a question more like a rant, I worked the last 3 days, got home at midnight last night and started working on it, was at it till 5am, then up again at 9 am stopped looking for a replacement at 1pm and now I'm back to work till midnight. fun fun. Gotta love everything including home depot being closed on easter but I'm working.
on another note, the strut was in fact blown, like basically completely worless so I hope it was the noise.
Old 04-04-2010, 11:59 PM
  #577
i was on my way to my family's house in south carolina for easter, and my tire (only 3 months old) blew out in the middle of bumfucknowhere, north carolina. i had to ride on a donut for almost 4 hours, going painfully slow, til i could get a new tire.
my question is does a full size tire+rim fit in the spare area? i would have checked but my trunk was full. i do a lot of long distance driving and i dont want to have to ride on a donut for an extended period of time, esp on the interstate.
Old 04-05-2010, 11:19 AM
  #578
(Mid-Atlantic)
No a full size rim/tire doesn't fit back there, at least not a stock 16 with thick tire, I've tried
Old 04-05-2010, 01:32 PM
  #579
ah poop. oh well, thanks.
Old 04-19-2010, 01:32 PM
  #580
6th Gear
RicoS80's Avatar
I had a tranny swap with after market fly wheel and pressure plate. I heard there was a master cylindar with a larger diameter that would fit our vehicle, anyone know about this?
Old 04-28-2010, 08:37 PM
  #581
So for no apparent reason I now have quad high beams. I can't imagine this happening spontaneously to be a good thing, any real ideas?
Old 04-28-2010, 10:57 PM
  #582
quad high beams? like when you flash them?
Old 05-01-2010, 12:49 AM
  #583
shnee's Avatar
Has anyone heard of JVT headers?
Here's a picture of them
Old 05-01-2010, 01:11 AM
  #584
shnee's Avatar
I saw that jfkhan guy or whatever his name was bought them, but I don't think he ever posted about them after that.
The inlet is slightly bigger than the ebay ones I've seen, I've read good/neutral things about them on other sites, and the price is right.
Old 05-03-2010, 12:03 PM
  #585
DaInFaMMuS1's Avatar
Try em out and let us know how it goes then, why not? What's the price of em?
Old 05-03-2010, 01:30 PM
  #586
(Mid-Atlantic)
I've heard of em, looked into them but I already had SS autochromes
Old 05-07-2010, 10:45 PM
  #587
davzilla's Avatar
do i have to change my ignition system to run CL-S heads on my 3.0? i'm starting to use oil quite a bit more than before. like i hit 9000km's since my last oil change and the VTEC wasn't engaging cause i was that low. I think it's safe to assume its the valve seals as i'm about to roll over 350,000kms. so i was thinking if i picked up a set of heads somewhere i could redo the seals myself and the just have my mechanic swap the heads, cuts down on the labour i would think.
so yeah...
Old 05-08-2010, 05:33 PM
  #588
shnee's Avatar
If I remember correctly, we 3.0s need the downpipe bent a little to use the j30 accord headers. These are like $120-150. I don't really want to go through buying them and getting them bent just to find out they are crap. Plus, the consensus here seems to be that headers aren't really worth any gains unless you get some uber expensive ones. I would be more likely to just buy them if there was no bending needed, and if it would actually benefit me in some way beyond having shiny new metal under the hood. Would heat wrap make a difference? I've heard it will add some gains by keeping everything cool, heard it will cause your shit to become brittle and break faster because it is holding in all the heat, and I've heard it won't really make a difference unless you are boosted.
So much shit I have no clue about
Old 05-08-2010, 07:48 PM
  #589
davzilla's Avatar
those ones probly don't need to be bent, it has a flex piece in the middle.
Old 05-11-2010, 07:54 PM
  #590
starboy2nv's Avatar
jvt = ebay
Old 05-20-2010, 11:11 PM
  #591
bRunCL's Avatar
Soo i have some 194 5led wedge lights for my headlight corners. I read some posts that said some people used leds in the headlights and blew fuses? I just want to know which fuses could possibly blow so that if it happens I know which to check. I have no experience with LEDs so anyone that has them in the corners chime in
Old 05-21-2010, 06:38 AM
  #592
mattastick's Avatar
I actually blew the fuse that the corners are on last night (no LED's and I'm not sure why the fuse blew either). It's a 15A fuse under the hood. The label is "Small Light" or something like that. The corner lights and instrument cluster all run off that 1 fuse. IIRC, it's the 2nd 15A fuse from the back in the 2nd line from the driver's side.
Old 05-22-2010, 03:54 PM
  #593
bRunCL's Avatar
Thank you!! exactly what i wanted to know. I dont have too much experience with lighting mods/upgrades.
Old 05-27-2010, 01:54 PM
  #594
i didnt want to start a new thread and i didnt know where to post this for all first genners to see...
anyway. back in NJ at miccici's auto body on rt73 berlin NJ there is a smashed up 97 CL, dark green. In it is a perfectly good gauge cluster, clock thing that surrounds the radio, ashtray, the bottom piece of the dashboard under the steering wheel, 1 tail light, a red AEM CAI, the steering wheel sans airbag and various interior panels.
anyway if you want any of this stuff PM me and I can get it for you.
  #595
but pretty much all the exterior panels are destroyed.
also, theres a spare tire.
Old 05-27-2010, 07:24 PM
  #596
mattastick's Avatar
2.2 or 3.0?
Old 05-27-2010, 08:28 PM
  #597
3.0. if it were a 2.2, id take the intake for myself.
Old 06-21-2010, 11:05 AM
  #598
P0401's Avatar
I have looked and looked at both dashes between the 97 and the 98/99 and can someone please tell me what the big difference is between the two? Is it just the wood grain and ashtray thats different
Old 06-21-2010, 12:15 PM
  #599
the whole radio bezel thing is different, the buttons for the clock are under it in the 98/99 (vs next to it in the 97...right?) and yes, the 98/99 has more woodgrain and the ashtray/cig lighter is different.
Old 06-26-2010, 02:20 PM
  #600
I reply 8 years later.. forgot my post...
Yeah quad beams when I flip on my high beams. I still havent' looked into it, but they're bright as hell.
Quick Reply: Question and Answer Thread
