Question and Answer Thread
#362
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
The offset
#365
with +35, the wheels will stick out more than they do +48. +48 is around stock, so if your trying to get it to look more flush or something, go with +35. if it rubs your fender, you can always get dennis to roll it.
#368
CL in lawnmower status
go with 35, it will give you more lip, and on a 7.5 inch wide rim, you shouldn't have to worry about that kinda offset at all
+48 would be too sunken in IMO
#371
flip rolled his rears, but he has 9 inch wide rears, and i think runs low 30's to high 20's positive offset.... so you won't be anywhere close to that
#372
im given a chance to buy a f22a1 longblock for 100$. this could be great for a turbo build and i could just build this engine while i have the vtec one in my CL. should i go for it?
#376
Runs on Dunkin
I;ve been hearing a rattling sound behind my dash when the fan is running, anyone else ever hear this? Its really annoying, rattly and buzzy like the fan is hitting something while its spins...idk
#377
(Mid-Atlantic)
(Mid-Atlantic)
sounds like your heater core is on it's way out
#378
Runs on Dunkin
That sucks, I really cannot afford anything right now. It only seems to happen when its really cold out too, the same thing happened with my two previous Acura's. It sucks being a broke college student.
#380
edit: i just checked ebay and they seem to start around 50 bucks, not bad, i paid over 100 for mine
#381
(Mid-Atlantic)
(Mid-Atlantic)
yeah u def can get one for around 50
#382
Runs on Dunkin
prolly sounds exactly like mine did, it's your blower motor, only replaceable, not fixable, take a look at the video of mine and tell me if it sounds close to the same https://acurazine.com/forums/showthread.php?t=696050
#383
but on the good side it's a bearing issue or something, so you can't really screw anything else up, just the motor itself
if you have any other questions, just bump that thread of mine, and i'll answer any questions i can, and i did the replacement myself btw
#384
Does anyone know if the rear motor mount on the 4cyl CL's is supposed to be the same on the automatics and manuals?
On 5th gen accords i believe the auto one is a little bit taller, but I grabbed one from a 5spd CL and it looks the same as the auto
#387
(Mid-Atlantic)
(Mid-Atlantic)
(Mid-Atlantic)
(Mid-Atlantic)
Airbag? For the radio? You shouldn't have to deal with the airbag, there are screws on each side of the console under the steering wheel cowling and the glove box, nothing near the airbag
#391
5th Gear
I picked up a 99 CL V6, with the typical transmission problems. Will the 05 TL transmission fit the Acura CL 3.0 V6 engine? From what I read it isn't suppose to have the issues of the previous V6 transmissions.
#392
(Mid-Atlantic)
(Mid-Atlantic)
Nope, won't fit.
#393
I've had a tapping noise while the car is in park or neutral that goes away when it's in any of the drive gears. I didn't think valve taps mattered on the gear the car was in? Any ideas? No other unusual noises that I can hear.
#395
Anyone know if our rocker panels are hollow or solid? Also, is there any way to stuff anything through them? Something like this on my buddy's Saturn:
I need to run 4 pieces of 1/0 wire through the car, from the engine bay (stock battery location) to the trunk for my additional battery bank.
So, does anyone know?
#397
Cool. Now, how'd you get it off of the car? Are there just clips or something on the bottom of it that hold it on? Also, do you think there'd be room in there to stuff 2 (or hopefully 4) pieces of wire that are the size of your thumb?
#398
(Mid-Atlantic)
(Mid-Atlantic)
Yep, should be clips all the way down as far as I know
#399
Thanks guys. I probably won't have any time to look at it till next week. Although next week, I should have another vehicle to drive daily, which will be very nice... I'll post pics of it when I get home this weekend. It's far from the prettiest thing in the world, but last time I drove it, I was getting 35mpg across town...
