Question and Answer Thread
This thread was requested by members of this forum. This thread is specifically for asking and answering questions about your car. This thread is meant for 1st Gen CL related questions only, this is a car forum, use it to ask questions about your car. No off topic conversations will be allowed. The format of this thread is that someone asks a question that they need a quick answer to. People can chime in with HELPFUL USEFUL ANSWERS This thread will be monitored and moderated, however don't make it difficult for us. We don't want to have to keep this thread clean or have to be deleting useless BS or rambling off topic discussions. If you don't have anything to add to the current running discussions or questions, do not post here or you will be in violation of the rules and dealt with accordingly. No parts requests Abuse of this thread will lead to closure or deletion. Please respect your fellow members and please respect the rules, let's make this a useful resource. |
Post a question that you need to know, and we can respond back with answers, please read and obey the rules
i'll start it off I guess.
Does anyone know if there is a manual steering rack of any other honda that us members w/deleted power steering could use instead of the power rack? Or is that impossible unless custom made? |
^ after doing some looking into that.. my best guess would be to try and find an accord one from the pre-power steering days. i think an 87 and below should do the trick if what i was looking at is correct. what i couldnt find is if there was ever an F/H that had non power steering.
For a CAI, what size inlet should the filter have to attach to the pipe? I need to know so I can order the K&N along with the ebay intake. Thought I asked before, but not sure.
Originally Posted by 1slo23
(Post 11040536)
It doesn't say anywhere on the ebay page? |
They make them in all different sizes. Be careful, I was about to order a filter for my pipe, but decided to double check it to be sure. It was 2.5", not 3" like I assumed. If you're ordering the pipe and filter from different places, make sure it lists how big it is in the description.
how do you know if your clutch is going? is there certain thigs to watch for... i think mine is the original or the 2nd only
the main sign is slippage, and the easiest way to test for it is to apply the brakes in 2nd or 3rd gear at around 3k rpm and floor it but push on the brakes to the point of slowing the car down and lowering the rpms, and if the rpms raise then it's slipping and on it's way out.
Another possible sign would be if it chatters alot upon taking off Oh btw I'm on the original clutch at 155k miles and still smooth with no slippage |
Is the inlet size on our throttle body 3 inches, and is there a power difference when getting a 2.5 inch intake opposed to a 3 inch? I KNOW MORE COLD AIR IS BETTER.
what distributor & ecu should I look for for the non-starting jdm f22b swap in my car currently? lack of CPS down low under the timing belt cover tells me the block is obd1...
and can I mod / hack the wiring on my CL dizzy? if so, how? |
^ Hit up a tuner shop I bet they could help you out
Originally Posted by TopGunEV
(Post 11041682)
Maybe I meant 2.75, not 2.5. This was a while ago :tongue:
OK Sounds good, so if I order a AEM v2 for our car, it is recommended to say f--- it to the aem filter that comes with it and just by a K/N 2.75 in Cone to prevent hissing. I'm having that go on right now and cleaning it didn't help. Sounds like a mini turbo lol...+15 HP
AEM V2 is a waste, just get an ebay intake and put a k&n filter on it
(Post 11044485)
If you spent $100+ on an aem or injen you'd really regret it later once you realized that all of the piping is exactly identical to that of ebay. It is the filter that matters. |
what's the stock 2.2 ECU and can / do I need to flash it to p39 to match my jdm f22b
I think i need to convert to obd1 does that mean new ECU automatically? |
Originally Posted by Gnate
(Post 11042333)
"Yeah, tow it in and we can get it running for about FIVE HUNDRED" the fuck outta here the longblock was 375 |
does 215/40/16 fit our cars i wasnt sure from the nob guide thanks
is any one good with the bpi velocity stacks? i heard you need a bigger filter which i got for free from my friend its 3 or 3.5 inch
Originally Posted by rice_plz
(Post 11045397)
Originally Posted by f22vtec
(Post 11045869)
(Post 11045397)
And that tire would fit a 16x8 or 16x7 wheel, and it would even fit the stock 16x6 but it's a bit of a stretch, I've put 225 series on 16x6 before though and ran them for thousands of miles with no problems. In fact, I think someone on here is running 225/50/16s I believe on stockies, can't remember who though. A good size for calculating tire diameters between different sizes is: http://www.miata.net/garage/tirecalc.html |
ive got 225 55 16's and a pretty subtancial drop
old pic http://i41.photobucket.com/albums/e2...r/car025-1.jpg |
yea i have an aem dry flow now
Originally Posted by spencer_homer
(Post 11049568)
no not really. ive got mm of clearance. but ive got 2.2 f 2.0 r but its used and i think its sagging lower than that
Anybody on here have experience with Skunk2 suspension parts? I'm looking at their Sport shock kit and just wanted to know before I would jump on a good deal....
Just one thing to add guys, quote the person who you're responding to or answering
(Post 11051029)
(Post 11032077)
:agree: Best suspension mod that I did, and I recommend it to everyone on here:thumbsup:
Do yours still squeak like CRAZY? Or do you think I just need to lube them up more? Because it sounds really bad when I go over bumps. |
(Post 11051217)
^ Grabbed that from that guys thread about having $500 to spend on his Cl, you were talking about energy suspension bushings...
avoid Skunk2 springs. very bouncy and uncomfortable ride.
(Post 11051790)
My PU bushings never squeaked, and my car has sat for a couple years since putting them on there, I would say lube them more
(Post 11052622)
What's the best kind? I tried astroglide and it just came right off after a few days
(Post 11052622)
http://www.amazon.com/Energy-Suspens.../dp/B000CN7B4I |
Originally Posted by Dicorp
(Post 11052267)
I found these HIDs online for 36.99 http://www.vvme.com/product/detail-20023.html
since theyre so inexpensive do you think i'll have many problems with them? or should i just get a more expensive set? |
(Post 11053143)
Thanks. I'll just save more for the KSports or D2's.
Originally Posted by South Jersey CL
(Post 11053787)
