need help wiring the h22a!
Old 08-21-2013, 02:57 PM
mytl9's Avatar
can anyone tell me what they did specifically when they wired up their dizzy? like what wiring to match up and everything. I know that one of the pages tell me that I can use our cl harness but its jus not working out.
Old 08-22-2013, 07:38 PM
DaInFaMMuS1's Avatar
What dizzy are you using? Internal or external coil? What does the connector look like as opposed to the H22 connector? Post some pics of what you're working with.
Old 08-26-2013, 03:21 PM
mytl9's Avatar
im using the dizzy that the motor came with. and its a internal coil. the connector has 8 wires. ill post the pic once I get home
Old 08-27-2013, 09:20 PM
mytl9's Avatar
Old 08-29-2013, 10:28 PM
Post a pic from the back so I can see what color wire/ pins are going where
Old 09-03-2013, 03:18 PM
mytl9's Avatar
Old 09-03-2013, 08:28 PM
Ok from the view of your connector, my pins are all the same on that side. On the harness coming from the dizzy side,
Black wire connects to grey wire
Red wire connects to white/blue
white connects to white
black/ yellow connects to black/yellow
yellow connects to pink
green connects to white/blue
blue connects to blue
yellow green connects to white/green
Let me know if that makes sense. If not I'll go take some pics for you. I hope that helps!
Old 09-04-2013, 03:02 PM
mytl9's Avatar
alright cool! now are you using the f23 harness? cuz I got a 99 acura cl and I heard that the 97 cl harness is different since its a f22
Old 09-04-2013, 03:09 PM
mytl9's Avatar
if you can post up the pic man that would be so much of a help man.
Old 09-04-2013, 07:43 PM
99 CL harness. I'll take some pics for you
97BlackAckCL (09-05-2013)
Old 09-04-2013, 08:11 PM
Distributor
Connector from distributor side
The wiring harness connector side is the same as the pic you posted. Also, I'm running an OBD2 to OBD1 jumper harness to a P28, not the CL ecu. A P13 also failed to even turn over my H swap for some reason, but the P28 from phearable.net worked like a charm.
Old 09-05-2013, 09:24 AM
mytl9's Avatar
Ok cool. Was there anything else that u did? Did you change out oil pumps?
Old 09-05-2013, 03:40 PM
mytl9's Avatar
Also what throttle cable are you using?
Old 09-05-2013, 07:45 PM
One custom CL
SupraManAG's Avatar
Did you get it out do you need my pics? I got the 97
Old 09-05-2013, 09:51 PM
I used the oil pump that came with my H23a swap
Old 09-05-2013, 10:18 PM
mytl9's Avatar
Oh so u have the h23a? I got the h22a. But your oil pump had the crank sensor right?
Old 09-05-2013, 10:54 PM
Don't remember off the top of my head if it did, it was years ago lol. Since my engine is internal coil like yours the dizzy wiring should match up though.
Old 09-06-2013, 02:39 PM
mytl9's Avatar
alright well ill see if it works or not. but yea what throttle cable are you using?
Old 09-07-2013, 10:39 AM
Using my F23 CL throttle cable. Found a writeup on the oil pump replacement also. I'll be adding it to the stickied swap thread
Old 09-08-2013, 09:10 AM
One custom CL
SupraManAG's Avatar
i wish we did this back when. I dont remember half the things that when into my swap. im a couple months shy of 10 years with it
Acura604
20
08-05-2017 12:55 AM
ITSJESTER
4G TL Photograph Gallery
10-13-2015 12:53 PM
MilanoRedDashR
10-08-2015 10:30 AM
SUPRMN84
10-07-2015 09:46 PM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
Quick Reply: need help wiring the h22a!
