Looking for a stock looking performance muffler!! WHERE??
I'm sick if gettting pulled over for my 3.5" can muffler... I'm really looking for a stock looking muffler that still has the straight flow design... Any suggestions will be appreciated... THANX in advance!!
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
hey, you shouldn't be getting pulled over for it, keep this in your car at all times!
Keep a copy of this in your car at all times!
27150.2. (b) A certificate of compliance for a vehicular exhaust system shall be issued pursuant to subdivision (a) if the vehicle complies with Sections 27150 and 27151. Exhaust systems installed on motor vehicles, other than motorcycles, with a manufacturer's gross vehicle weight rating of less than 6,000 pounds comply with Sections 27150 and 27151 if they emit no more than 95 dbA when tested in accordance with Society of Automotive Engineers Standard J1169 May 1998.
SAE Standard J1169 on how to test your exhaust noise level:
Decibel meter is held 0.5 meters (20 inches) from the exhaust tip, and the test is done at 1/2 the engine's maximum rated RPM (redline).
Any exhaust modifications after the catalytic converter are legal as long as the exhaust noise is below 95dB. If you got a ticket for modified exhaust, have this test done by someone with a dB meter (try local car stereo shops), have the person doing the test write out the results of the test, along with the date, time, and location of the test, then sign the paper. Bring this when you appear in court. The charge will likely be dropped.
btw, what are they actually ticketing you for, what are they saying you are doing wrong?
nah... they pulled me over.. check for my caty converter... look around.. gave me a ticket for expired insurance... IT JUST EXPIRED that night and i got the ticket at 1:02 AM... gave me a fix it ticket for no front license plate and tinted windows
edit: how does the straight pipe sound, where did you relocate the o2censor? Also so obvious they saw you didn't have a cat?
stright pipe sounds alittle deeper than the cat.. almost a little rumble.. as for the 02sensor I just pulled it out since the 2nd one is just to make sure that the cat is working... check engine light comes on though.. LUCKY ME i put my car into stock form for a smog test just a week ago... so.. answer is NO they didn't catch me.. CLOSE though.. I had stock header,cat, intake when they checked.....
DAMN~ THEY EVEN HAVE THOSE MIRROR things that looks under your car!!
SSM Accord V6 6 Spd
magnaflow 14820 i think is good. althonxp had one and he said it looks stock (its the same exact size) but with better performance. quiet when you want and growls when you need it.
-James
Originally posted by athlonxp
Basically for all the characteristics mentioned by EPS Sniper above, go with the magnaflow. However, I have the 14258, with 35131 magnaflow tips. This will look the most close to stock ever. Here take a look at this pic:
-James
-James
James can you post more pics of it on the car?
ExcelerateRep
Sponsored Sales & Group Buys
01-06-2016 09:59 AM
ExcelerateRep
12-11-2015 12:58 PM
Joseph Stansbury
34
12-04-2015 01:57 PM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
