Key Fob
Key Fob
does anyone knoe the code to program the key fobs in our first gen CL's? I saw the dealer do it once, but theres no dealer close to me now so I got to try and do it myself, any help ?
chips and smokes, lets go
these are the directions i got with my new remote:
-turn on ignition
-within 4 seconds push either lock or unlock
-within 4 seconds turn the ignition off
-within 4 seconds switch ignition on
-repeat process twice
-within 4 seconds press either lock or unlock
-system should now lock and unlock vehicle to indicate programming mode activated
to be honest, i just kept swtiching the ignition on and off while pushing the button on the remote until it stated working.
-turn on ignition
Originally Posted by Sleep_DEPRIVED_Sleeper
here's the instruction on how to reprogram them...
Applications:
* 94 - 02 Honda Accord (all trims)
* 97 - 99 Acura CL (all trims/egines)
PROGRAMMING REMOTE TRANSMITTER
NOTE: Procedures must be performed within the stated time limits. Four
remote transmitters may be coded into system.
1. Turn ignition on. Within 1-4 seconds, press remote transmitter lock or unlock button while pointing transmitter toward keyless entry control unit. Turn ignition off within 1-4 seconds. Go to next step within 1-4 seconds.
2. To program another transmitter, repeat step 1). Four transmitters may be coded into keyless entry system. If more than 4 transmitters are coded, the first transmitter code will be erased. After all desired transmitters have been programmed, go to next step to verify system operation.
3. Within 15 seconds of programming final transmitter, press lock or unlock button. Verify that door locks operate and go to next step.
4. Check door lock operation using each transmitter. Turn ignition off and remove key. Remote transmitter codes are now stored in keyless entry system control unit. Reverify door lock operation.
Applications:
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by asianspec
use the search button.
soupi
14
11-15-2015 11:15 AM
