hydrolocked
Old 06-03-2013, 12:59 AM
2.2CL owner
cl-baller201's Avatar
hydrolocked
My engine sucked in water today. I tried to start it but to no avail.
I have a cold air intake. Anybody have any advice ?
Hopefully it will start up again.
Old 06-03-2013, 04:14 AM
Your Friendly Canadian
Aman's Avatar
Received 1,484 Likes on 1,048 Posts
Try pulling the spark plugs and cranking it over to get any water out. Trying to start it right after probably didn't help, though. Water isn't compressible so you may be looking at bent valves.
Old 06-03-2013, 08:33 AM
2.2CL owner
Bent valves ?
Old 06-03-2013, 10:11 AM
timeizmoney22's Avatar
Just another reminder for me to get the bypass filter I've been putting off on getting for like a year now! Hope it all works out ok man!
Old 06-03-2013, 01:05 PM
2.2CL owner
I tried to turn on the car but all I hear is a click and nothing happens.
Old 06-03-2013, 10:36 PM
Low and Slow
YtseJammer's Avatar
Let the car sit for a while to dry out. Pull the plugs and try cranking the engine while pumping the gas pedal. If you didn't suck up too much water it may take a while but it should start up after enough tries.
cl-baller201 (06-04-2013)
Old 06-04-2013, 10:12 AM
2.2CL owner
Will do, thanks.
Old 06-04-2013, 01:13 PM
6spd FTW
Tehvine's Avatar
I would probably turn it over with a wrench once the plugs are out to get a lot of the water out. Going to be hard for the water to get out fast enough to avoid breaking more shit if you just hammer on it with the starter. Once no more comes out when you turn it over by hand, then use the starter.
Old 06-04-2013, 01:46 PM
2.2CL owner
You can do this with a wrench? When I try to start it, I hear a click but the car does not crank. I think the starter is damaged. What do you guys think ?
Old 06-04-2013, 02:00 PM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,409 Likes on 3,021 Posts
I've been preaching this for years, a BV saved my engine back when I got caught in a hurricane/flood. Sorry to hear about your car baller, I would definitely let it sit and dry out with the spark plugs out as others have suggested.
Old 06-04-2013, 02:28 PM
2.2CL owner
Ok, I'm going to remove the spark plugs and let it dry out.
Old 06-06-2013, 06:01 PM
2.2CL owner
I have let the car dry for a few days. Today, I tried to start it with the spark plugs out and it did not turn on. All I heard was a click, but it did not start. I put the plugs back on and no start.
Do you guys think the starter is shot ?
Old 06-07-2013, 09:00 AM
I honestly do think it's f'd! I try not to drive in pouring rain lol and definately stay away from puddles!
Old 06-07-2013, 09:13 AM
(Mid-Atlantic)
If you're just hearing a click, then the starter is not turning over
Old 06-07-2013, 12:55 PM
2.2CL owner
Hopefully, it's just the starter that I need to replace.
Old 06-07-2013, 01:49 PM
(Mid-Atlantic)
Old 06-08-2013, 11:32 AM
DaInFaMMuS1's Avatar
If it doesn't turn over after you install the starter, start looking for a new engine sir.
cl-baller201 (06-09-2013)
Old 06-08-2013, 12:14 PM
My"S"exyUA7's Avatar
I hope so too...I hydro locked my mazda and I found a fist sized hole threw the back of my engine block...I decided to scrap the car (for $1000) and buy my TL-S...still have yet to put a CAI on it. Good luck to you!
Old 06-08-2013, 01:29 PM
breck569's Avatar
my 07 TL has a cold air intake and i sucked up water at the end of my driveway and it died immediately. The car would not start. I ended up removing the intake, and shoved a vacuum hose down the throttle body for atleast an hour untill i could see or feel no more water. The car then started up after a hesitation and several start ups. This was almost a year ago, and the car is still driving fine.
Old 06-09-2013, 09:48 PM
2.2CL owner
"Fist size hole,"
holly shiznit,
Old 06-09-2013, 09:51 PM
2.2CL owner
If that is the case, I'm gonna see if I can get my hands on a prelude engine.
Old 06-09-2013, 09:55 PM
2.2CL owner
I tried to start her up today, but no start. I gave the starter a good whack to see if it would start but to no avail. I'm gonna get my hands on a starter and see if that will get her up again. I wanna hear this engine ignite again.
Old 06-10-2013, 08:07 AM
(Mid-Atlantic)
Old 06-11-2013, 05:17 PM
"Fist size hole,"
holly shiznit,
It was slammed with an injen cai...ran into a flash flood and sucked water into the engine. Knew something was seriously wrong when they were putting it on the flatbed and could see oil coming out from the bottom...next morning at the shop they found the hole and could see everything busted to shit! That's worst case scenario and hopefully that's not the case for you...any luck yet?
Old 06-12-2013, 07:51 AM
(Mid-Atlantic)
Old 06-12-2013, 08:07 AM
240benzo's Avatar
oh man that doesnt sound like good news for your wallet either way xD
Old 06-12-2013, 12:36 PM
(Mid-Atlantic)
Old 06-19-2013, 09:02 PM
So what was the verdict on this?
Old 06-26-2013, 07:30 PM
2.2CL owner
I removed the starter and the battery but both checked out ok. I reinstalled both but the car does not turn on.
Any ideas ?
Old 06-26-2013, 09:34 PM
Aman's Avatar
How did you test the starter to see if it was good?
Old 06-27-2013, 10:47 AM
Schiernbeck's Avatar
I hydrolocked my car yesterday and the motor is toast. Ugh. Not a good day
Old 06-28-2013, 11:31 AM
(Mid-Atlantic)
Damn guys
Old 06-29-2013, 03:23 PM
2.2CL owner
I removed it along with the battery and I took it to autozone; both checked out ok.
Old 06-30-2013, 08:23 PM
Did you try to turn the engine over manually at the crank?
Old 07-17-2013, 08:37 AM
Almost have the new motor, starter, air filter, and carpet put back in the car. It has been a long month.
Old 07-18-2013, 08:48 AM
(Mid-Atlantic)
Old 07-19-2013, 11:05 AM
See statement from above
Old 07-22-2013, 09:29 AM
(Mid-Atlantic)
Oh ok, thought you were the other member with a new name, sorry to hear, glad to hear you're getting things back together. Wonder how baller is fairing.
Old 07-17-2014, 03:29 PM
kakins23's Avatar
Mine is at the dealer now because my engine was hydro locked!!!! Life sucks!
Old 08-09-2014, 11:30 PM
2.2CL owner
Would this engine fit?
http://www.jdmenginezone.com/engine-...uetop-97+.html
Quick Reply: hydrolocked
